Old 12-18-2008, 01:45 PM   #1
nickbain
nickbain's Avatar
nickbain is on a distinguished road
No Gauge Cluster or Radio
K the car is a 2003 alero 2.2 5-spd.
Sometimes the gauge cluster and radio stop working totally and sometimes there are lights on is the cluster (service vehicle soon, brake warning light, air bag, security, low fuel {because the fuel gauge is reading empty when gauges aren't working}) Sometimes everything works like a dream. The car is running fine with no ideling or start-up issues. I got the batt and alt tested both tested GOOD for the past two days the car has been in a heated garage with a small heater under the dash to dry everything out still doing the same thing. Does anyone know what could be up?
2003 Alero
2.2 5speed
Grey
1996 GMC Yukon 4x4
nickbain is offline   Reply With Quote
Old 12-18-2008, 02:34 PM   #2
AGT
AGT's Avatar
Sounds like a short or an exposed wire grounding but is your headunit stock?
Have a good day
Old 12-18-2008, 04:47 PM   #3
nickbain
nickbain's Avatar
ya stock HU (monsoon)
2003 Alero
2.2 5speed
Grey
1996 GMC Yukon 4x4
Old 12-19-2008, 01:03 AM   #4
Ask a mech buddy to check out the wiring diagrams on a program like shop-key. Figure out which wires are the power source and ground for the cluster.
Once you know that check to make sure both are working properly, and also that theres continuity between them on the cluster.
If you can catch it when they're not working that'd be the best.
Old 12-19-2008, 01:48 AM   #5
That's a problem with the Class 2 data bus. That's what controls the cluster and radio.
