Old 12-20-2008, 04:06 PM   #1
Bmorezcmunee
Bmorezcmunee's Avatar
Bmorezcmunee is on a distinguished road
white lithium grease/wheel bearing
this might be a dumb question but, is white lithium grease ok for wheel bearings?
Bmorezcmunee is offline   Reply With Quote
Old 12-20-2008, 04:22 PM   #2
i don't think its made for higher temps like the wheel bearings experience....
Old 12-20-2008, 06:11 PM   #3
guiguilandry
guiguilandry's Avatar
actually the wheel bearings are sealed units, you can't grease them...
Custom or Nothing...
www.demonautosport.ca
Old 12-23-2008, 02:20 PM   #4
CactusWill
I'm sure that theres a way to get grease in there, as it can definately come out. One of my bearings had all the grease washed out in one day of driving through flooded waters after a hurricane. But if you're going to consider doing all the work to get to it, just replace it already. 100 bucks and you're done with it, rather than trying to rig quick fixes.
Old 12-23-2008, 04:09 PM   #5
When I had mine put in, me and the mechanic coated everything down there in white grease.
Just to you know... help out a bit.
Old 12-23-2008, 11:48 PM   #6
Bmorezcmunee
yeah i just ended up throwing the bearing on and torquing everything down. one thing i do have to do is torque the axle nut to 247. i didnt know my torque wrench went that high lol
Old 12-24-2008, 09:02 AM   #7
hahano404
Old 12-24-2008, 09:28 AM   #8
omg death!
Old 12-24-2008, 09:57 AM   #9
Beholder88
Beholder88's Avatar
Beholder88 is on a distinguished road
Wow, that torque spec is way to high. You'll end up replacing that bearing again soon if you leave it like that. I'm not sure exaclty what you should torque it to, I've seen some other posts on here about it though.
Beholder88 is offline   Reply With Quote
Old 12-24-2008, 10:45 PM   #10
When you torque that lock nut, you're not actually doing anything with the bearing. It's only holding the CV shaft to the hub.
