03-26-2008, 11:06 AM
#81
such an awesome concept. i have no traction due to instant almost peak boost lol
03-26-2008, 11:43 AM
#82
I totally understand that. When I set for 15psi, I start into boost at around 2500 RPM and hit peak by 3500. That much boost that fast is totally retarded on torque steer and traction. But my friend said it looks impressive when he was riding next to me, breaking loose at a roll.
03-26-2008, 08:08 PM
#83
Originally Posted by BlackJack
Just a thought, did you mean from redline in 1st, how much does it drop when it pops into 2nd?
If that's the case, I set the shift point at 5800 under WOT, then it shifts to 2nd and starts winding out again from around 3800 to 4000, well into boost still at that point.
Yeah, that's what I meant, mine is dropping to about 4000 to 4200, which is not too bad after all the years of abuse.
One thing to watch for is, if you increase the line pressure for performance tuning, fluid may be forced out and cause a small leak. What I have had to do is go thru the water box first, then up the pressure via a switch, to avoid getting it on the track. Hopefully yours won't have that problem, though.
With your tranny, you should be able to use stock settings and still get good results.
03-27-2008, 12:16 AM
#84
actually, I do need more pressure than stock, because if I don't, the clutches will slip under that much torque. I'm not going through that again
However, keep in mind, after installing the "Performance Shift" switch, all I do is hit a toggle switch and go from stock pressures and shift points to increased pressure and higher shift points.
03-27-2008, 02:33 AM
#85
thats pretty damn sweet man. But I got to ask ya how much money you think you have dropped into your Alero not including how much you paid for it.
Live to Ride
Ride to Die
03-27-2008, 07:44 AM
#86
engine, about 3 grand
trans swap, about 2 grand including trans and axles, plus original fabrication, and my time to make it work.
so, all in all, about $5k (which is almost the cost of just a supercharger kit minus the extra goodies.)
03-27-2008, 10:08 AM
#87
So hows it looking for getting to the track???
03-27-2008, 10:38 AM
#88
How hard is it to transfer the 4t65 files to the PCM?
03-27-2008, 11:38 AM
#89
Upgraded from 70% to 80%. Remaining details are:
1) tires purchased/installed
2) weld a bead around the throttlebody throat because I keep blowing couplers off at 15psi
3) Fabricate hood spacers at the rear hinges so the hood will fit/clear.
4) Finish tweaking
With the PowrTuner, it's just a matter of making sure the subset categories match, then import the data such as PPM for speed calculation from the OSS, and input proper gear ratio, then extrapolate shift tables and torque management/reduction values.
03-27-2008, 02:29 PM
#90
Are we still looking around Saturday 29th of March in the evening???
03-27-2008, 04:27 PM
#91
Things keep getting better. Went up to 15psi and broke off 2 trans/motor mounts. Lets see if we can get it fixed in time. Too much torque? Don't know, but this is pissing me off
03-27-2008, 11:39 PM
#92
^^ sounds like a good problem, well sorta of
03-28-2008, 12:11 AM
#93
extrapolate
some word, lol.
This thing must be ridiculous to watch in person. If only I was anywhere close to AZ to get a look-se, damn.
03-28-2008, 01:37 AM
#94
Boost Guru
You ready to go turbo yet?
What kind of clamps are you using?
03-28-2008, 01:52 AM
#95
clothes pins, you dork
T-bolt clamps of course.
03-28-2008, 02:28 AM
#96
Boost Guru
Ha...just curious, I didn't know for sure Usually the T-bolt clamps hold up pretty well.
03-28-2008, 07:37 AM
#97
actually, they do hold up pretty well, until you hit 12psi or more. Then you have to do something extra to get them to hold.
03-29-2008, 05:36 PM
#98
Good Luck 2nite BJ!
03-30-2008, 05:21 AM
#99
no-go......but I do have new motor/trans mounts installed now.
03-30-2008, 07:15 AM
#100
take you time and get it right. the last thing I want to see is a video of you blown you motor on the first pass. with the money and time you have in to this build I am sure you cant wait to put you foot in it
