Old 06-04-2008, 07:54 PM   #121
tejohnson
tejohnson is an unknown quantity at this point
Originally Posted by BlackJack View Post
Calling you in about 5 minutes.
Left you a message this evening. Will sell ARP studs to Oil Pan, Timing Cover to Flywheel. Assembled. You pay: $1k + Shipping. If you or someone else grabs it, I'll be parting out everything else.
Regards,
Todd E. Johnson
13.475 @ 108.43
| Updates/Pictures/Video |
For Sale in pieces: 1999 Pontiac Grand Am
tejohnson is offline   Reply With Quote
Old 06-04-2008, 08:04 PM   #122
Got the message, thanks!
Old 06-08-2008, 01:30 AM   #123
Originally Posted by YALEROYNOT View Post
hey blackjack how hard was the 4t65 swap ? is there a write up on it ?
thanks
No write-up, due to no time and/or patience.
don't bother unless you're using the HD (from S/C 3800). use GTP flexplate and TC, steal the lower drivers side trans mount from a 4t65 monte and weld on to cradle, then grab the upper torque braces (dog bones) from a chevy venture 3400 with both engine and upper radiator supports, then get custom axles made with 4t65 inners and 4t45 outers, rewire, reprogram, and I'll leave the shift translation to you. I'll give you a hint....1-2 solenoid uses same on/off commands, but the 2-3 solenoid is exactly opposite.
