04-29-2008, 05:00 PM
2.2 vs 2.4 vs 3.4
who wins in a race off line all brand new? and also why? difference between all 3?
04-29-2008, 05:02 PM
who cares
2.2/2.4L manual does
04-29-2008, 05:22 PM
Originally Posted by [ion] C2
who cares
LOL
04-29-2008, 05:30 PM
3.4 bc it is a higher number.
But really if I was to guess, I would say 2.4 and only bc I have one.
stock vs stock vs stock....
i'm pretty sure the v6 does. for obvious reasons
04-29-2008, 05:38 PM
But its heavier... Idk. Someone needs to put this to the test. I got a 2.4 and a 2.2. The 2.4 is faster.
04-29-2008, 05:43 PM
yeah, I know for sure a 2.4 would definitely beat a 2.2
and the v6 has a lot more power than both I4s, so I'm gonna go with the v6 also
04-29-2008, 05:44 PM
3400:
- 170HP
- heavier
- automatic
2.2L
- 140HP
- much lighter
- manual
2.4L
- 150HP
- much lighter
- manual
Having a manual takes off like 0.8 sec from the quarter mile times, at least from results I've seen on j-body.
04-29-2008, 05:45 PM
New and Improved
on paper its v6 all the way
04-29-2008, 05:46 PM
No... on paper it's manual I4 all the way.. on emotions it's the V6 because ITS BIGGER AND HAS MORE HP LOL IT MUST BE BETTER
and no one takes into consideration the higher weight and the fact that it's an AUTOMATIC. compared to the I4 manual, the I4 will WIN.
04-29-2008, 05:50 PM
if your talking just off the line, 2.4. but stock for stock i think the numbers i found awhile back were 15.9 (3.4) and 16.0 (2.4) in the quarter. but i think those were like test numbers off a brand new vehicle and its been a while since ive read it.
04-29-2008, 05:59 PM
meh... i think you're giving the 2.4 too big of a wieght advantage... considering i'd peg the v6 at about 5o to 100 lbs heavier... my 2.4 wasn't slow for a grocery getter... but by no means was it fast... and my mom had the v6 and it was faster... and that's my story
04-29-2008, 06:06 PM
ok.. i'll resay mine...
stock vs stock vs stock ALL AUTOMATICS...
v6 should win.
04-29-2008, 06:07 PM
So you took them to the track and actually compared the times, or are you simply relying on your "butt dyno" on how "fast" each car was?
If you guys really care about which engine/transmission combination is the quickest stock, go to the track and find out... but a manual will always be quicker than an automatic stock for stock. Since the V6 is automatic, and the I4 can be manual, the manual I4 will have weight advantages in that the engine is lighter, and the transmission is lighter. The V6 has a heavy automatic transmission, and it's bigger. Clearly the I4 manual and V6 auto will be close, but the I4 will win.
It's that easy.
04-29-2008, 06:12 PM
i got the v6 my ex had the v6 grand am gt he sis had 2.4 alero beat both of us and she has 200 pounds on us her and her man were in the car i know that sounds dumb but 200 pounds does count i mean it literally destroyed our v6 i was amazed i thought bottom line was the hp difference but she proved us wrong and all were stock. idk wierd to me what in everyones opinions is the nicest motor in quality and design wise the 2.2?
04-29-2008, 07:02 PM
ya the Eco
04-29-2008, 07:41 PM
The 2.4L 5-speed coupe (if driven well) should be the fastest stock Alero.
While the 3.4 has +20 hp and +45 tq, the 2.4 5-speed is ~100 lbs lighter plus less power is lost through the transmission. Also, you could launch the 2.4 5-speed more aggressively.
I'm sure the 3.4 has it in the high end, tho.
2001 2.4L GX 5 speed
04-29-2008, 08:00 PM
3.4 ftw.......my 3.4 can beat my 2.4 by more than 4 car lengths. here is the weight diffence
2001 2dr gl with 2.4 2997 lbs 150 hp 155ft-lbs
2001 2dr gls with 3.4 3060 lbs 170 hp 200ft-lbs
2004 2dr gl1 with 2.2 2950 lbs 140 hp 150ft-lbs
these numbers are all using edmunds.com
Originally Posted by adam337
Goal - Mid 11s all motor.
04-29-2008, 08:29 PM
i vote for 3.4 as well.... it'd be very close with a 2.4 manual but still...I just have to say no based on self-experience
2000 Chevrolet Malibu LS
04-29-2008, 09:53 PM
2.2 all the waye
even though it lacks power and size the 2.2 ecotec is the most dependable and longest lasting engine.
the v6 has problems galore and is infamous amongst gm mechanics for necessary power train repair post 75 thousand miles
the 2.4 like the 2.2 is small for the weight for the engine... but is worse because its design lacks the efficiency and durability of the 2.2
the 2.2 is fantastic.. other than the lack of power... its modern computer dependent system deletes the distributor cap problems, and only needs high grade oil changes.
