Any idea why it has lost power? mabey new plugs would help but, It is a 5 spd. i used to speed up up hills in 5 th gear. know i have to down shift just to keep my speed?
TEAM PRODIGY-TEAM CROSSFIRE-TEAM XS POWER WWW.TEAMPRODIGY.NET WWW.CROSSFIRECARAUDIO.COM
2010 BASS RACE WORLD CHAMPION 140.0DB - 149.9DB
2009 Bass Race World Champion 140.0-149.9db Class
give it a tune up, see what happens, hopefully thats the problem. I would say check your plugs, plug wires, fuel filter, air filter, things like that......
Any other symptoms?
Stuttering at idle, missing? ---Probably the plugs. Could also be fuel filter. Could also be that the injectors need to be cleaned. Fuel filter is cake to replace. Injector cleaning, try dumping 2 containers of fuel injector cleaner and run the dog snot out of it.
Running a little hotter than normal? ---Could be Cat getting clogged. Doubtful but possible.
Just some ideas, I hope they help get you motorin' again.
It kind of slow to speed up. when the rpms get up to 3000 then it moves like it used to. but under 3000 it is slow to rev up. also I could go up hills in 5th gear at about 70-75 buy the top it slows down to about 50. and it never did that before.
Replace your spark plugs. I replaced them at about 70000kms and instantly gained some power/fuel efficiency. I didn't use those crappy platinum ones either, they are good for longevity but not for power. I used the plain old champion copper ones. :thumbsup:
