Go Back   Aleromod.com > General Help > Paint and Body Work
Old 07-08-2009, 08:21 PM   #1
whiterider00
whiterider00's Avatar
door frame trim removal
ive searched and couldnt find anything. i need to know how to, if its even possible, remove and replace the black trim on the B-pillar area of the doors. it almost looks like it can just slip off, but im sure its more complicated than that. thanks in advance.
-Josh
Old 07-08-2009, 09:37 PM   #2
bdyman
ok dude its not a "b-pillar" ok?? please
its call door frame applique, here we go...........
pull the weather stripping down, and you have to remove the belt molding, if you have the belt molding tool it makes it allot easier, but if you dont, the belt moldings are clipped and pressure fitted on so....with the window down......grab the inside of the belt molding, and as you grab you push down and up, keep doing that to break the molding free
inside the applique there are 3 screws once you pull back the weather stripping, then pull out and over, comes right off,
and then just reverse the process
Old 07-09-2009, 08:03 PM   #3
Atmosphere
Atmosphere's Avatar
Atmosphere is on a distinguished road
I was wondering about this too, thanks bdyman.
whiterider, are you getting new ones or are you going to sand/paint your existing ones?
2K 3.4L 4DR GLS
Atmosphere is offline   Reply With Quote
Old 07-09-2009, 09:39 PM   #4
whiterider00
dunno yet. i have a spare alero lying around, waiting for someone to buy it...he knows who im talking about...so i may swipe them off that one. and bdyman, i know its not the b pillar, thats why i said b pillar area, i just forgot what the technical name for it was. ill give it a shot since mine are dented and starting to rust a little bit, and the other ones look new.
Old 07-10-2009, 02:40 AM   #5
_01Alero_
A.S.S. Translator
_01Alero_'s Avatar
_01Alero_ is an unknown quantity at this point
woh woh woh... a spare alero? details please? if it isn't already sold or is at least manageable HIT ME UP!....
_01Alero_ is offline   Reply With Quote
Old 07-10-2009, 02:06 PM   #6
brianl
brianl is on a distinguished road
Removal Procedure
Pull back the rear of the window run channel weather-strip retainer.
Remove the front door outer belt sealing strip.
Remove the screws (2) from the font door frame applique.
Remove the font door frame applique (1) by sliding upwards.
Installation Procedure
Position the front door frame applique (1) to the front door.
Install the font door frame applique (1) by sliding downwards.
Install the applique screws (2) to the door window frame.
Install the front door outer belt sealing strip.
Pull back the rear of the run channel weather-strip.
brianl is offline   Reply With Quote
Old 07-10-2009, 02:07 PM   #7
brianl
Rear Door Frame Applique Replacement
Removal Procedure
Pull back the window run channel weather-strip from the forward edge of the door.
Remove the outer belt sealing strip.
Remove the screws (2) from the rear door frame applique.
Rotate the rear door frame applique (1) forward.
Remove the rear door frame applique from the rear door.
Position the rear door frame applique (1) to the rear door.
Rotate the rear door frame applique (1) rearward.
Install the screw to the rear door frame applique (2).
Install the rear door outer belt sealing strip.
Pull back the front of the window weather-strip retainer.
Old 07-10-2009, 02:12 PM   #8
bdyman
Old 07-14-2009, 10:21 PM   #9
whiterider00
thanks for the help. with the shitty weather, and the rediculous amount of work ive had, i havent had a chance to tackle this yet, but it looks easy enough that it shouldnt take too long.
