08-21-2008, 03:37 PM
Gas Smell With A/c On
Guys, I need your help...
I started my car the other day and turned my A/C on and within seconds there was a strong smell of gasoline. I turned the air off, waited about 30 seconds and turned it back on. Still the gas smell. So i turned off my car let it sit for a few min and started again with the a/c on... no help. I live in TX and its too hott to be without a/c lol. But this doesnt happen everytime i turn on the a/c.
Does anyone know what's going on? I've never experienced anything like this b4.
The only repairs I've had done lately was having the catalytic converter replaced.
Thanks in advance for any and all help with this
and btw,... its an 01' 2.4
08-21-2008, 03:53 PM
Look for a gas leak?
08-21-2008, 04:17 PM
Umm are you parked when you do this? My cars exhaust gets into it when im parked but when I drive I get nothing.
08-21-2008, 04:24 PM
The smell of raw gas it a leak as will have to be fixed ASAP.
Don't know how fuel is delivered on the 2.4 though. I had a "O" ring go bad in the fuel reg on the 3400
08-21-2008, 04:54 PM
don't know why it would happen only when the a/c was engaged
08-21-2008, 05:03 PM
Both parked and driving. But it's not all the time.
Me thinks it's the only time he smelt it
08-21-2008, 05:04 PM
do u know much it would cost if it is the "O" ring? and ill have it serviced tomorrow
08-21-2008, 05:05 PM
It cost me about $40. only took 1/2 hour, if that's the problem
That was on the 3400 thou
08-21-2008, 05:06 PM
why don't you open your hood, and take a damn look at the engine bay and see if there's fuel sprayed all over. it's not that hard. look around the injectors, see wetness.
replacing injectors/o-rings/fuel rail crap is not hard at all and can be done very quickly. the hardest part is figuring out how the heck to unplug the wires.
08-21-2008, 05:07 PM
I did find the point of leaking pretty quick
That sounds good... but i dont know crap about working with an "O" ring though. hmmm...
08-21-2008, 05:09 PM
In that case, leave it to a pro.
I know carbs not FI systems
08-21-2008, 05:10 PM
i will do that
08-21-2008, 05:11 PM
on vacation
lol.. replacing an O ring is like taking a tiny ass rubber band and putting it around the tip of your finger- its easy as pie.
WILL NEVER FORGET
08-21-2008, 05:15 PM
darnit... i wish i where more mechanically inclined...
08-21-2008, 05:18 PM
Ditto. At least you could check for where the leak is coming if you dont want to repair it yourself. Open the hood, check around the fuel rail, start the car and try to notice if something is leaking somewhere.
Ion, those freaking plugs on the injectors.... UGH!
08-21-2008, 05:25 PM
srsly that's why i'm not putting my Cobalt injectors in yet
1. don't want to have another epic fuel splash
2. don't feel like figuring out how they come off again
meh i know fuel injection but no clue on carburetors, old school, FI ftw
08-21-2008, 05:41 PM
Ok, so i had my coils replaced a few months back... could it be something with that?
08-21-2008, 06:17 PM
Unless they knocked something loose on the fuel side. The 2 are not connected
If it was a coil probelm, it would run rich or lean and you'd smell it behind the car, not under the hood
