Old 06-12-2006, 11:09 PM   #1
cruisinalero
cruisinalero is an unknown quantity at this point
ok i believe our cars must have these specs for rims...
Bolt Pattern: 5x115
Offset Range: 38 to 45
Wheel Size Range: 15x7.0 to 20x8.0
OEM Tire Size (Front): 225/50-16 (225x632 mm)
Max Tire Dimensions: 245x657.0
now i was wondering if these rims would be able to fit on our cars?
Wheel Size: 18x8
Bolt Pattern: 5x114.3
Offset: 40
or
Wheel Size: 18x8
Bolt Pattern: 5x115 or 5x114.3
Offset: 20
i probably wont get these rims for awhile (if they fit), but it is just good to have some idea of what would fit, and how to manipulate them so they can fit
cruisinalero is offline   Reply With Quote
Old 06-12-2006, 11:21 PM   #2
jackal2000
jackal2000's Avatar
the first ones will fit but those second ones....offset of 20? i dunno about that.
Old 06-12-2006, 11:25 PM   #3
cruisinalero
ok so rims of a bolt pattern of 5x114.3 will work???
Old 06-12-2006, 11:27 PM   #4
jackal2000
jackal2000's Avatar
yes, but you might need hubcentric rings. al depends on how snug the fit is. just remember you want the weight of the car on the hub not the lugs.
Old 06-12-2006, 11:34 PM   #5
cruisinalero
how much are hubcentric rings, pretty cheap i assume?
where can i purchase them, local automotive store?
