04-06-2009, 03:31 PM
#21
And how many ohm resistor did you put?
Take Life's Curves Sideways, and Drift!
04-06-2009, 03:49 PM
#22
depends on what color/led your using....
white/blue = 470
red = 960
iirc
04-07-2009, 08:23 AM
#23
its gonna be all Blue relayed to a switch on the center console.
Is the site super bright leds trustworthy??? whats the delay for shipping ???
For the PRND123 I think I'd go with twist ons... unless normal LEDs arn't much harder to install...
04-07-2009, 08:31 AM
#24
just get
(it has 4 leds on the sides and one in the middle.) its available in their store.
and be done with it. adding leds takes alot more work. You gotta prevent shorting... hide leads/wires. pain in the ass.
yank the bulb out (can push from the bottom with a small screwdriver and the bulb pops outta the holder) and replace it with the one from superbrightleds, that i posted.
04-07-2009, 11:22 AM
#25
Kool... where did you get yur Oldsmobile signe beside yur shifter?
04-07-2009, 12:59 PM
#26
Carved it into my unused ashtray.
04-07-2009, 01:02 PM
#27
LOL SWEET!!! was it hard??
04-07-2009, 01:04 PM
#28
Not tremendously. More tedious... Like any led work.
Pretty sure I had a thread for that, too
04-07-2009, 01:33 PM
#29
I meant the carving out part lol
04-07-2009, 01:36 PM
#30
Used a dremel.... It was the tedious part.
I cut the symbol out of a sheet of paper, used that as a template, painted the symbol on it, then cut the painted part. Filled it with epoxy after.
04-07-2009, 01:48 PM
#31
Is there a lot of bulbs on the car that can be switched to LEDs from the SuperBrightLED.com site?
I think i m gonna forget the oldsmobile symbol lol!!
04-07-2009, 01:55 PM
#32
Virtually all can
04-07-2009, 01:58 PM
#33
Do the ones in the cluster really show up through the greenish plasic?
04-07-2009, 01:59 PM
#34
What about the exterior lights? all of them too?
If so...WOW ... i got a lot of work for this summer
04-07-2009, 02:04 PM
#35
Yes,all them too. Keep in mind, hid is the best for headlights. Don't waste your money on the led ones.
I'm curious to see if the led versions are as bright as the halogens... I'm guessing, no
04-07-2009, 02:18 PM
#36
Why not, I m sure they d be real nice!
What gage wire do you use for your custom worked LEDs
04-07-2009, 03:54 PM
#37
22 mostly. Some old 18ga is lingering
And with led headlights, I fear the led's ability to project...long distance
04-07-2009, 03:59 PM
#38
I see...
your a real source of LED info!!
Thanx
04-07-2009, 04:02 PM
#39
Haha... I try
04-07-2009, 04:14 PM
#40
I m checking out what i can change and its very interesting...
but a lot is still going to be custom, I need to check for the LED brake lights, to make sure ppl see me when i brake ( tinted tails).
and i cant find which fit the Fog lights...
