02-16-2009, 12:12 AM
Yes. The picture has the second section on backwards. The piping should be directed away from the exhaust port holes. If it is truly for the L61 2.2L Ecotec and not the LN2 2.2L engine (which is routed like in the pictures, since the exhaust side is at the front of the car, the piping needs to go under the engine and back). Yours just needs to go straight back from the exhaust side.
It's probably going to rust, and that shininess will go away. You should have JET-HOT coat it with a high temperature coating before installing it.
02-16-2009, 12:15 AM
Thanks for looking C2.
02-16-2009, 12:19 AM
I was looking at the pacesetter headers specifically for our 2.2, and there seems to be a difference where it attaches to the engine. Compare these.
02-16-2009, 12:25 AM
different style...
the top is 4-2-1
the bottom is 4-1
the top one is pictured wrong, the bottom portion should be installed opposite so it all goes away from the flange
02-16-2009, 12:30 AM
Yeah I want the 4-2-1 style, pacesetter pic was just something to compare the fit against. I'm going to buy them.
02-16-2009, 12:43 AM
looks sweeter too
should definitely get it coated though
02-16-2009, 12:55 AM
Any alternatives to Jet Hot? Would be a PITA to receive them, ship them back out and possibly end up paying a brokerage (importing) fee twice.
02-16-2009, 09:51 AM
Wouldn't like... High heat tremclad to the same thing?
Just not look as good?
02-16-2009, 01:02 PM
I dont think tremclad will do it. I've emailed a local place that says they can do high temp coatings for headers.
http://www.induction-dynamics.com/main.html
02-16-2009, 01:28 PM
Tsudo makes a 4-2-1 header for the ecotec I think.
Also, on the two pics you posted, I dont think the first one is for the ecotec, as it looks like this one is bolting on the front of the engine in the engine bay, as the second is bolting on the back.
02-16-2009, 01:43 PM
like i said, the ebay person has it pictured wrong, the bottom portion bolts the other way around
02-22-2009, 04:17 AM
Shit I had set of tsudos
Their sittin in my garage gaskets blew plus I wanna pacesetter
02-22-2009, 04:24 AM
oldsmobile is real JDM lol
02-22-2009, 04:37 AM
1999, RED Alero GX
02-24-2009, 07:59 PM
$135 (canadian) to my door. Didn't even pay import/brokerage fees, the guy shipped it as a commercial sample. I'll post up a sound clip when I get them on.
02-24-2009, 08:11 PM
thats gonna make ur engine bay look way better, after i took mine off my bay looked empty
02-24-2009, 08:12 PM
The Aleromod PITA
r u saying the header pipin is supposed to go under neath the motor, im pretty sure mine comes off the back side adn goes straight back
02-24-2009, 08:17 PM
If it went straight back, it would be going through the passenger compartment. It curves down and under the car.
My engine bay looks awful, so it could use the improvement. Still not sure about getting it coated though, I was quoted $200 for 'ceramicoat' special powder coating. Whats regular powder coating cost? I haven't been able to find a local shop that does it.
02-24-2009, 08:21 PM
if u dont get em coated they turn gold in like 2 mins
