Old 03-30-2009, 10:22 AM   #1
CactusWill
Aftermarket Oil Filter Ring Leaking ?
I've done about 8 oil changes on the ecotec so far, and replaced the oil filter O-ring every other time... Problem is, I try to buy the AC delco filters, but the AC delco filter does not come with a new O-ring. So I buy aftermarket brands every other time to get a new O-ring, but the last 2 have been leaking.
Anyone else had this same problem? What brand oil filter comes with a good O-ring?
Old 03-30-2009, 06:20 PM   #2
Valley olds
Valley olds's Avatar
I have changed the O ring only once. Usually I get the o reillys filter. I think its called microsomething. I only changed the o ring the first time, and havent changed it since. Still no leaks.
Old 03-30-2009, 06:22 PM   #3
dhurst765
dhurst765's Avatar
dhurst765 is on a distinguished road
I Have Changed It Once In 4 Yrs
dhurst765 is offline   Reply With Quote
Old 03-31-2009, 11:37 AM   #4
I don't recall changing mine either. However there is a part number for the oil filter with the whole cap from ACDelco.
ACDelco # PF458G
GM # 12605565
Old 04-04-2009, 10:16 AM   #5
CactusWill
Took the filter off, hosed the filter cover with brake cleaner to clean the threads, cleaned the ring and put it back on, this time dry without priming the ring. Still leaks.
Originally Posted by Cliff8928 View Post
ACDelco # PF458G
GM # 12605565
I guess thats what I need to get. Thanks
Old 04-12-2009, 09:59 PM   #6
CactusWill
Got the filter and installed it, holding tight as a drum now thx cliff
Old 04-17-2009, 01:52 PM   #7
AleroDrime
The Aleromod PITA
AleroDrime's Avatar
i havent an issue with fram filters
