03-16-2006, 07:45 PM
Junior Member
does anyone know if hids from a nissan maxima would some how work on an alero
03-16-2006, 08:15 PM
do you drive a oldsmobile maximalero? ok then, no
Brent: and in the end...... cherrington is still a cum dumpster whose closest contact with HOT women is through a car internet forum ........... so as long as we can agree on that........ we can all go back to being friends.
Being Brents friend is teh hotness
03-17-2006, 01:25 AM
Yes they will, as long as you take the projectors out of the maxima headlights and put them in your alero housing (assuming they aren't too big)
If I did went to college...
03-17-2006, 09:48 AM
[boosted 2.4L]
you would need to locate the ballasts, too. the hid bulbs need the ballast to run them. the projector itself is not really that important. you can run them without it.
03-17-2006, 10:50 AM
You obviously don't know what you are talking about.
If you attempt to run a D2S bulb in a stock housing you will realize you just wasted a lot of money. First of all it won't fit, second your light output will look like poop because the bulb isn't rebased for the proper focal length. Not to mention that even with the proper focal lenght HID's in halogen reflective housings are glare factories, and you should ALWAYS retrofit a projector.
03-17-2006, 11:18 AM
Originally posted by b-spot+Mar 17 2006, 03:50 PM--><div class='quotetop'>QUOTE(b-spot @ Mar 17 2006, 03:50 PM)</div><div class='quotemain'><!--QuoteBegin-2fst4u@Mar 17 2006, 08:48 AM
you would need to locate the ballasts, too.Â;-) the hid bulbs need the ballast to run them.Â;-) the projector itself is not really that important.Â;-) you can run them without it.
[/b][/quote]
Oh Snap....Thanks for playing...
03-17-2006, 11:21 AM
Originally posted by b-spot+Mar 17 2006, 10:50 AM--><div class='quotetop'>QUOTE(b-spot @ Mar 17 2006, 10:50 AM)</div><div class='quotemain'><!--QuoteBegin-2fst4u@Mar 17 2006, 08:48 AM
[/b][/quote]
glare factory? my hids work fine sans projectors
retrofitting a projector doubles the cost of hid for what...a small bit of glare? how retarded is that
did you steal these hids? hids from maximas are one of the most stolen things of cars these days
03-17-2006, 12:59 PM
The Founder
Originally posted by eag182+Mar 17 2006, 12:21 PM--><div class='quotetop'>QUOTE(eag182 @ Mar 17 2006, 12:21 PM)</div><div class='quotemain'>
[/b][/quote]
What b-spot is saying is absolutely true. You can put in HID's with 9006 bulbs, and it will work but compared to a projector-retrofitted HID kit, you are comparing apples to oranges. With stock halogen housings, you are just putting in a really really bright light, and the result is that it sprays out a TON of glare. It might look good compared to halogen bulbs, but it isn't even close to as good as with projectors.
To sum it up....
stock halogen < silverstar halogen (or comparable)
silverstar halogen << HID 9006
HID 9006 <<<< HID w/ Projector Retrofit
03-17-2006, 09:50 PM
Junior Member
ok thanks to all you guys but i decided not to buy them
to manny problems
