Old 11-05-2007, 10:03 AM   #1
windsoralero
windsoralero is on a distinguished road
01' Alero - Bad gas mileage in cold weather
I have a 2001 olds alero 3.4 that seems to have an issue.. or at least to me... I have found that during the summer i can drive my on avg about 350- 400k per tank of gas.... now as soon as we get a little cold weather that mileage immediately drops to about 250 - 300.. now this was never really a problem until last year thats when it first appeared... just looking for some suggestions on how to fix this.
2nd problem.... as of today my temp sensor does not seem to be moving. This morning as i was driving to work i noticed that the little needle was not moving... although the car was blowing out nice warm air....
Any help is appreciated...
Mark
windsoralero is offline   Reply With Quote
Old 11-05-2007, 10:07 AM   #2
Vtolds
H&B Shipping Agent
Vtolds's Avatar
Well when it is cold people let there cars warm up and blow there heaters to get the ice of the windows and that takes a lot of gas to do that. I would say your car is probably fine. I dont know if winter mix gas makes a difference for gas mileage but that may also be the other problem.
Old 11-05-2007, 10:23 AM   #3
colder air = denser air
more air = more fuel
Old 11-05-2007, 10:23 AM   #4
windsoralero
I normally keep my heater turned down until the car is warm.... and its not that it has be freezing cold... it can just be cool like an early fall morning.
Old 11-05-2007, 10:36 AM   #5
They also change the fuel mixture in the winter time. They run it witha little more alcohol to prevent the fuel from freezing in your car. Alcohol burns quicker than gas, therefore making you go through more to get the same place.
Old 11-05-2007, 11:17 AM   #6
windsoralero
Our gas had not switched over as of yet...The supply I believe is still the summer gas. Normally when they switch to winter gas all the gas stations put up new signs to advertise there winter gas.
Old 11-05-2007, 01:33 PM   #7
dtldiaspora
dtldiaspora's Avatar
dtldiaspora is on a distinguished road
theres winter and summer gas? man im retarded i never knew that, but i live in florida so guess that has never been a problem for me
dtldiaspora is offline   Reply With Quote
Old 11-05-2007, 02:39 PM   #8
01silveralero
01silveralero's Avatar
it doesnt matter where u live you dont pick where ur gas comes from so there's winter and summer blend for everywhere
Goal - Mid 11s all motor.
Old 11-05-2007, 05:23 PM   #9
freakout
freakout's Avatar
freakout is an unknown quantity at this point
The further north you go the ratio for the winter blend increases. If your car isn't coming up to proper operating temp the computer will run it in "choke" mode and it will burn more fuel.
freakout is offline   Reply With Quote
Old 11-06-2007, 05:10 PM   #10
windsoralero
What can I do to find out if its coming up to temp.-
Old 11-06-2007, 05:42 PM   #11
Vtolds
H&B Shipping Agent
Vtolds's Avatar
Do you have your winter tires on yet? That will also make you lose some MPG since it is a lot stickier more aggressive tread it takes more power to move your car.
Old 11-06-2007, 05:46 PM   #12
windsoralero
No winter tires Vtolds... I have Potenzas on my car I spent alot of time trying to find a good tire for all season..something better than the crappy Eagles RSA's
Old 11-06-2007, 07:58 PM   #13
freakout
freakout's Avatar
For the temp. The temp gauge. If you want to verify that it's working right a meat thermometer that goes up to 190 . Not sure if the overflow tank is circulated with the coolant. But thats the only spot tou can put the thermometer. A thermastat isn't very expensive. To test that the thermastat is not working put it in a pot and boil it checking the temp it opens with the meat thermometer. I believe we have an 195 thermastat stock. Try putting your hand around the upper rad hose. From dead cold you should be able to feel the thermastat open (when the hose begins to warm up). Check your gauge if it isn't close to normal op temp then you need a thermastat.
