03-23-2004, 07:29 AM
Let's Play Army!
I may have overlooked it in my search, though, so bear with me.
I got my oil changed yesterday, and the light is still on. I tried the same thing as the "Low Tire Pressure" light...nothing. Is there a different way to go about turning this particular light off?
Thanks.
Originally Posted by black
03-23-2004, 08:24 AM
First, check the oil. I wouldn't put it past some places to forget to refill it.
I don't know how you're doing it but just in case:
-remove fuse panel cover on driver's side
-turn key to "ON"
-press red "RESET" button, CHANGE OIL should flash
-press and hold "RESET" until car chimes, CHANGE OIL should go away
If that doesn't work, bring it back to the place you got it changed, play dumb, and ask them to reset it 'cause you don't know how "They always do it for me, you must have forgotten."
03-23-2004, 08:25 AM
Quote by Velocity on another board.
Put your key in the ignition and turn it to ON but don't start the car. Open the drivers side fuse panel and you will see a big red button with RESET written on it. Press it once and your oil change light should start flashing. Hold down the reset button until you hear some chimes. That will reset the oil light.
Pheenz Motorsports Founder
03-23-2004, 12:35 PM
Easier way.. turn car to on (but don't start)
Floor the gas 3 times
Turn it on
If I did went to college...
03-23-2004, 01:11 PM
^^^^^^^^^^^^^ Thats the way I do it, it's a lot easier.
03-23-2004, 07:34 PM
Yup, that's how I do it too. Just a little quicker.
03-23-2004, 07:58 PM
Owner
never heard of that one.
Beware of the BackStabber
03-23-2004, 08:22 PM
Let's Play Army!
neither have I, but I'll give it a shot. :thumbsup:
03-23-2004, 08:50 PM
I'veheard of it before becasue thats how you have to reset it on my parents Seira but I never thought it would work on our cars
2002 GL2 4DR, MYMODS:In dash 7" VGA Widescreen monitor, XM Satalite Radio, Clarion Amp, 2 10" Audiobanhn DVC Subs Hidden HitchTrailer Hitch, Grill Mesh
03-23-2004, 08:52 PM
thats all I use, the gas pedal technique.
03-23-2004, 08:56 PM
Does that work on the tire pressure as well?
03-23-2004, 10:58 PM
I heard of that one but didn't know how to do it
03-24-2004, 04:29 AM
Let's Play Army!
worked like a charm! Thanks! :thumbsup:
Don't know if it'll work on the tire pressure light though.
03-24-2004, 07:34 AM
Turn it on
Good to know.
03-24-2004, 01:20 PM
no, doesn't work on the tire pressure one.
03-24-2004, 02:12 PM
My 99 had the red reset button, but my 04 doesn't so flooring the gas three times with the key turned on, but not started is my only option! Don't know if this is the same for others as well???
03-24-2004, 05:43 PM
That blows.
03-30-2004, 11:27 AM
Turn it on
I tried that and the dude at Midas tried it a billion times and it never worked. I have a 2000 GX. Booooo.
