05-01-2016, 03:58 PM
Cam tower seal
Has anyone done a how to on the cam tower seals? I tried searching but couldn't find one. Is it as easy ad pulling the IDI cover, and taking out the bolts on the tower coversand swapping out the gasket?
http://www.ehow.com/how_7703691_repl...et-24l-gm.html
Reason: Found info on a different site
05-04-2016, 04:49 AM
That ehow is wrong. Its a bit more complicated that that... if memory serves, you have to pull the timing cover as there is two bolts behind the cam timing gears that go into the cam covers.. but you don't need to pull fuel lines or the fuel rail
edit to add: There is two bolts per cover behind the cam timing gears, if you plan on doing a cam swap, now would be a good time to do it since you will already have it all apart, which is my plan.
1998 Bravada
05-05-2016, 12:20 AM
Thanks for the heads up, been trying to get info on this for awhile and that was the best I could get.
I would assume to open that cover you have to drain out all the oil in the system correct?
05-05-2016, 12:32 AM
Found a blown out scetch of the side of the engine, also ion c2 posted a link on http://www.aleromod.com/forums/showt...light=Cam+swap that has an entire breakdown of the engine (just found now found the thread)
05-05-2016, 08:45 AM
Yeah you'll want to drain the oil. Doing this job is a PITA, as you need to pull the front engine mount to get the timing cover off...just loosening the cover won't give enough room to get the cam gears off. Plan on roughly eight hours of work... six if you're really fast.
1998 Bravada
05-09-2016, 11:15 PM
Do you have to pull the cam gears, timing chain, etc off for the bolts to the cam covers or can you get them out threw the wholes in the gear? If I have to take it all off then I might as well put in all new shit while I'm in there for preventative maintenance
05-10-2016, 09:03 AM
Yup, gotta pull off the cam timing gears.. good thinking to do timing set since it'll be all apart. Don't get an el cheapo timing kit.. spend the dough and get a Cloyes part # 90390S.. yes get the full kit including new gears, guides, and tensioner...old gears will chew up a new chain quickly and commonly the tensioner will fail before the chain. Make sure to read the instructions/warning included with the new tensioner. New tensioner comes in compressed state. AFTER chain, guides, etc. are installed you need to release the plunger (easy enough to do, just gotta press it in with a screwdriver and it will pop out) If you don't you will skip time.
1998 Bravada
