07-28-2004, 06:41 PM
i just bought the electroluminesent halo glow overlay gauges, and im having trouble with the inverter. it says i need to connect the black and red wires to a powere source, and ive taken apart my steering wheel trying to get to that swicth that controlls the headlights, and i cant get to it........ i cant find a way to give the gauges power.... can someone help me, most likley someone who has done this before!?
AUTOBOT
07-28-2004, 07:10 PM
i dont see any wires i can connect, cause they are all multi color and theres no way in knowing anything, so all i can do is run power from the battery, but that means my gauges will perminatly be on.......all the time.........even when the car is off....
AUTOBOT
07-28-2004, 07:13 PM
theres no on or off switch from the inverter.........all i want is for the gauges to come on when the headlights come on (auto) just like it would normally..... issed: issed: someone help
AUTOBOT
07-28-2004, 07:31 PM
Senior Member
I spliced into the wire that controls the cubby-light. The little bulb in the top of the cubby.
It works perfectly, When I lock the doors the guages blink, and when I unlock them, they blink twice. really cool.
It was easy to splice into the line, and feed it up into the back of the guage cluster area.
Hope this helps!
<img src=\'http://www.luckywebdesign.com/Alero/lloyd%20alero%20sig1.jpg\' border=\'0\' alt=\'user posted image\' />
07-28-2004, 07:32 PM
^^ yep, that is exactly like I wsa going to suggest.
07-28-2004, 07:37 PM
cubby light ok ok, refresh my memory where exactly that is, how to get to it, and what clor the DC wire is?
AUTOBOT
07-28-2004, 07:38 PM
How familiar with automotive wireing are you? If not very much, may want to have someone do it for you.
07-28-2004, 07:43 PM
well my dads doing it with me right now, so im sure he knows more about it than i do, all we need to know is where to splice the cubby wire........cause we dont know where that wire goes, i mean i have my whole gauge cluster and steering wheel taken apart, and i myself dont know the specific cubby wire
AUTOBOT
07-28-2004, 07:44 PM
do i pull the bulb out? and follow it from there? and what color is the DC wire? for power
AUTOBOT
07-28-2004, 08:36 PM
well since no one decided to post any help........i'll just try to figure this out tommorow........ <_<
AUTOBOT
07-28-2004, 08:47 PM
uhhhh anyways, i turned the key, and all the little lgihts that say "SES" or "brake" or "oil temp" etc etc. well since these are overlays, they are very uneven with the lettering, was there some sort of trick , in having them even with the overlays!?
AUTOBOT
07-28-2004, 09:42 PM
these were the slip ons right? and not the stick ons?
try some double sided 3m tape if they are like the one's i've got, it'll help in alignment, it just takes some time to get em on right
i'm assuming you have the wires right too
but if not, take the cluster out, and run the power to the gray wire that runs into the gauge cluster, and ground to somethin like the top left bolt behind the cluster
smirking is important
follow the titans
08-01-2004, 03:06 AM
well i ran the wire to a 10 amp fuse that controlls all the interior lighting, so everything that the interior does the gauges do too. B)
AUTOBOT
