02-13-2005, 02:08 AM
jesus listen to this, i pulled my gauge cluster out because i wanted to change the bulbs behind the needles, and everyone said, there are 194 bulbs behind them, so i just now get to them, and thinking that its just like any other bulb, i pull the poor 194 bulb out, yeah well its a little longer than normal 194 bulbs and yeah it was definatly attatched to a metal section that is very important in holding the bulb. so basically i wasnt supposed to pull the bulb out, and now i have no room to solder it back in, and im out of solder anyway. god im so f***ed....... issed: issed:
AUTOBOT
02-13-2005, 02:27 AM
where my knickers at?
If youre just changing regular 194s and putting regular 194s, you dont have to solder anything, Just pick the little pieces of wire off the metal contacts, they prolly just melted.
If youre doing led 194, then I dont know, good luck.
--UPDATE-- $88,000 in debt.
02-13-2005, 02:43 AM
Boost Guru
LED's are the same way...just make sure the contacts on the LED bulbs are touching the metal contacts on the bulb holder. if you put it all back together and some bulbs dont work at first, they're just in the wrong way. twist out the holder, turn it a half a turn and put it back in. it should now work fine.
02-13-2005, 02:56 AM
i get what hes saying, the piece that contacts between the bulb and the gauge board came off with the bulb.......i didnt have that happen so i dont know if you can de-sp;der the contacts off the old 194's that were in there and put that piece back and then do what you gotta do.....
02-13-2005, 03:00 AM
How the hell did it come out with the bulb? Unless the contact piece broke...maybe that's what happened?
I haven't looked at mine for a while so maybe I'm not visualizing it right...
Even so, just get new little holders(whatever they're called), you shouldn't have to solder anything.
02-13-2005, 04:41 AM
well i did what you said, i also had this problem for the dome light LED's. and for some reason i had 2 polar bulbs. and didnt know it till i was done, and a whole bunch of bad stuff happened to me, like i dropped 2 of the screws under the steering column, ho man, it sucked but i got it done, i'll try to get some pictures up, if i can get up off my fat ass.
AUTOBOT
02-13-2005, 12:32 PM
fat ass? whatever dude.
lol
02-13-2005, 03:28 PM
you know what skyler! f*** your couch ok!
AUTOBOT
02-14-2005, 01:18 AM
Boost Guru
Originally posted by Alero-+Feb 13 2005, 04:41 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (-Alero- @ Feb 13 2005, 04:41 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Spilner521@Feb 13 2005, 02:43 AM
well i did what you said, i also had this problem for the dome light LED's. and for some reason i had 2 polar bulbs. and didnt know it till i was done, and a whole bunch of bad stuff happened to me, like i dropped 2 of the screws under the steering column, ho man, it sucked but i got it done, i'll try to get some pictures up, if i can get up off my fat ass. [/b][/quote]
glad it worked for you. lets see some pics :thumbsup:
I dropped screws into the steering column a bunch of times. i actually found them
3 or 4 times...and i think i'm still missing a couple.....
02-14-2005, 02:18 AM
so where are the pics fatass?
02-14-2005, 09:45 PM
im too over weight to take them
AUTOBOT
02-14-2005, 11:19 PM
AUTOBOT
02-14-2005, 11:20 PM
those are blue LED's on the temp and gas gauge needles, then it has red LED's for the RPM and Speed needles. i also changed the dome light bulbs and cubby hole bulbs as well as the shift bulb. go check it out in showcase.
AUTOBOT
02-15-2005, 12:31 AM
are those in stock or after market guages?
02-15-2005, 12:37 AM
why they are aftermarket my good sir
AUTOBOT
02-15-2005, 01:10 AM
reverse halos... ~25 on ebay.
04-12-2005, 05:04 AM
where do you get the led 194 ??????????????
