03-02-2010, 04:46 PM
#41
The Aleromod PITA
appreciated replies too
the reason the headunit was swapped out to see if was the issue was the owner of shop said i was over analyzing by blaming the grounds. Claiming it was likely a problem in the head unit. But the brand new RCA did the same thing
03-02-2010, 05:28 PM
#42
No problem when you figure this out let us know, cause this is interesting to say the least.
03-02-2010, 05:39 PM
#43
The Aleromod PITA
will do and with connel have a similar issue id like to see this solve issues for others
03-02-2010, 06:19 PM
#44
possible that the amp is really REALLY poorly shielded, and is emitting RF, which is being picked up by the radio elements?
really far fetched... but seemingly possible.
03-03-2010, 03:25 PM
#45
The Aleromod PITA
if it was a lowend amp i could see that but its an effin Memphis, but still ill see friday what he thinks about swapping in a new amp to see if it helps, it has a lifetime warranty, the only reason i let his boys install it
03-03-2010, 06:55 PM
#46
i have a alpine amp. and i haven't really tried to fix it. i blame the window antenna, and just don't listen to it, or turn off the subs
03-03-2010, 07:07 PM
#47
I poop alot
Do you have a cap, if so where is it grounded? I would also like to know where you have your amp grounded?
03-03-2010, 11:01 PM
#48
The Aleromod PITA
no i do not have a capacitor anymore, im told that my class d amp doesnt need one or 4 gauge wire
but its grounded on the rear seat bold driverside corner
03-03-2010, 11:27 PM
#49
no cap here. and my amp is grounded on the bolts holding on the strut tower
03-04-2010, 07:02 PM
#50
I poop alot
Okay no problem there, that in my opinion is the best spot to ground and amp in the trunk.
And you're sure the defroster is off then it makes the noise?
And you guys have tested the window to make sure you even have an antennae because those things going across the glass can get broken.
03-04-2010, 07:44 PM
#51
which is funny... i've scrapped the inside of my window (frost on the inside) more then once... and they are all still perfect.
03-04-2010, 09:04 PM
#52
I poop alot
Not every window is made equal.
