07-05-2010, 09:22 AM
running hot
my car runs a lil warm around the 3/4 mark
it just started doing this it used to be just under the half mark,
any ideas whats wrong>
07-05-2010, 09:35 AM
Coolant low? Thermostat bad?
07-05-2010, 10:34 AM
coolant is good
thermostat was replaced 2 months ago
07-05-2010, 11:29 AM
well you most likely didnt bleed or "burp" the cooling system after you changed the thermastat it sounds like.
07-05-2010, 11:58 AM
oh it was running at normal temp after i did the thermo. and i bled the piss out of it last week for 20 mins
07-05-2010, 02:29 PM
you can try putting more water and less coolent and/or buy some watter wetter from advanced
07-05-2010, 02:45 PM
ita pretty much all water
07-05-2010, 02:54 PM
since you live in a hot tropical place it could be just normal but you could just buy a bigger rad
edit when does it get hot? in traffic? or just cruzin?
07-05-2010, 03:23 PM
ok ive had the car here for 3 months and this past week is when it started doing this
where can i get a bigger rad
it gets hot cruzn and in traffic
i can be goin 75 and that pig is dam near 3/4
07-05-2010, 03:30 PM
My car does this too, also been wondering about it.
I completely flushed and changed the coolant and T-stat about a month ago. When I sit on a hill or stopped in traffic it slowly goes up, but when I start driving it goes back to 1/2. Also, you can smell the cars oil when its hot, but it isn't leaking or anything.. Bad seal on the cap letting fumes out possibly for that I'm guessing.
07-05-2010, 04:16 PM
mine dont return to half at all unless its turned off
07-05-2010, 08:44 PM
when was last time cooling system been serived? i'm pretty sure its the coolent
edit. prettry sure you can buy the rad anywhere, internet, local car parts or whatever. just make sure you measure if you decide to buy a bigger rad.
07-06-2010, 03:42 AM
coolant is pretty much just water
do i gotta run the dex garbage?
im thinkn of upgrading the rad and fans
07-06-2010, 04:06 AM
These cars run too hot for plain water. Flush it well and fill with a good mix.
07-06-2010, 12:25 PM
Since I've had my car it has always run at 3/4 sitting still...this is of course dependent on the weather. In summer months she gets up there in winter it never move past half temp. I'm by no means a car person but are the fans turning on when they are suppose to? If the thermostat is good, and the coolant is good, and there are no leaks so the level is good...what else can it be? Could there be a pump problem I wonder. Maybe one of these engine gurus will be kind enough to help you out.
07-06-2010, 06:06 PM
yea my fans are comming on im leaning tward a partially cloged rad .
07-06-2010, 10:28 PM
then theres your problem
07-07-2010, 01:15 AM
that could be it, maybe
07-07-2010, 10:21 AM
Since it's all water you should have no qualms about pullin off the radiator hoses and using a hose to blast some high pressure water through the radiator... get a decent nozzle that'll seal pretty well, I use this:
makes a good seal so you can really blast it out.
Then you need a good 50/50 (or preferrably 60coolant/40water) mix.
Running straight water is a terrible idea... You could be boiling the whole system, and if you're unlucky you've already destroyed something!!!
water boils at 220*. The radiator cap raises the boiling point by 3xRatePSI (aka 45*). Thus your coolant WILL boil at 265*, and with your car running at 3/4 that's getting dangerously close.
The proper mix of coolant not only freezes at a lower temp than water, but also boils at a higher temp, protecting your engine from boiling and destroying gaskets!!!!!!
07-07-2010, 12:46 PM
What happens if you overflow your radiator reservoir a little bit?
