Old 01-23-2012, 11:18 AM   #1
03gxeco
03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute03gxeco has a reputation beyond repute
reverse lights not working
okay i put the car in reverse and the back up lights do not come on. i looked at the bulbs an they seem fine. what else could cause them to stop working? i cant seem to find a fuse that is for them either.
i just need a little direction. like where the fuse is located and whats it labeled as? Or what else to check for. is there a switch in the shifter some where i can check or something? unfortunately i do not have a repair manual yet which is why i am asking for help here.
and one more thing, my rear driver side door does not lock. when i push the power lock button the door makes the sound like it has locked but i can still open it and the plastic lock knob inside the door does not move. i tried pushing that and it didn't budge. any ideas? thanks in advance.
03gxeco is offline   Reply With Quote
Old 01-23-2012, 11:29 AM   #2
Alerojester
Alerojester's Avatar
Alerojester is on a distinguished road
Send a message via Yahoo to Alerojester
there should be a sensor in the console that senses when its in reverse but im not 100% certain on that
stock 2.4-building a WAI to a CAI 3A Racing muffler- ~Kicker Door speakers and Power Accustic rear speakers 10% tint 18x7.5 Alt Sonix, 2001 GLS sedan
Alerojester is offline   Reply With Quote
Old 01-23-2012, 12:46 PM   #3
jhubbz
⌘ Irish Pride
jhubbz's Avatar
backup wiring diagram for an 03 Ecotec
Done lost my mind
Old 01-23-2012, 02:56 PM   #4
Vella's Alero
Vella's Alero's Avatar
Vella's Alero is on a distinguished road
Do the cars have a sensor in the gear box for reverse? In my new car I had the same problem and there was a sensor in the transmission or gearbox (can't remember which) which had come unplugged. We plugged it back in and everything was fine.
SOLD - 1999 GL Sedan-LA1 3400
Installed - CAI, drilled and slotted rotors w/ Carbon fibre brake pads.
OWN - 1996 Rover 414 - replaced engine with a 1.7TD Isuzu lump and gearbox, Uprated brakes, Custom seats and interior trim, MG ZS 11 spoke wheels, Custom bodywork, Custom LED taillamps, Custom gauge surround to hold 2 52mm gauges (filled with boost and oil pressure gauge)
Vella's Alero is offline   Reply With Quote
Old 01-24-2012, 04:31 PM   #5
03gxeco
the link doesnt work to the wiring diagram. i still havent figured it out yet. almost got hit because they person didnt see me backing up (no back up lights)
Old 01-24-2012, 04:34 PM   #6
first just pull the bulbs and look. or even put in a known good one. its easy. rule it out and dont just assume they are ok. and its a whole lot easier then anything else involving the reverse light. while you go check ill look up the diagrams.
edit: inspect fuse B/U LP/BTSI in the underhood fuse block. should be a 15 amp fuse
Old 01-24-2012, 04:43 PM   #7
Old 06-18-2012, 02:21 PM   #8
03gxeco
reviving old thread here but, i got to the thing in the trans, checked it over and it looks fine but my revese lights still do not work.
Old 06-18-2012, 03:28 PM   #9
invest in a spotlight
Old 06-18-2012, 03:31 PM   #10
03gxeco
lol. that doesnt sound like a bad idea at all.
Old 06-18-2012, 05:40 PM   #11
could be bad internaly. if your sure it has to be the swtich then it could just be bad inside the switch and you will never see it outside just by looking at it.
