01-08-2011, 03:03 PM
How to take this off
im trying to remove the black bezel trim so i can put on some metal trim.
any ideas on how to remove the plastic glass from the bezel trim?
just call me "Doc"
Check out my alero!
Aleromod Showcase Video
01-08-2011, 03:09 PM
I'm not sure but I think it's siliconed on, in which case a heat gun or hair dryer would melt it, then you just pry gently to pull it off.
1987 Honda Rebel 450
01-08-2011, 03:13 PM
could i stick it in the oven, like i did with my headlights?
just call me "Doc"
Check out my alero!
01-08-2011, 03:22 PM
its not that difficult to use a heat gun, i used a hair dryer and it took me 15 minutes.
2003 Olds Alero 2.2L Eco
Ttop191: who gives a damn what everyone else thinks, if you are proud of it thats all that matters, dont let others persuade you into thinking what you like is wrong.
01-08-2011, 03:27 PM
you could but if you have a heatgun that would probably be faster anyways
01-08-2011, 05:29 PM
I'd worry about warping it in the oven, IIRC it's not as robust as the headlights.
I know Harbor Freight has a $10 heatgun on sale sometimes.. totally worth the money I've used mine a lot.
01-08-2011, 08:03 PM
Thought u had to dremel them
out
01-08-2011, 09:16 PM
yea i tried the hair dryer trick but the one i have isnt too powerful.
so i put it in the oven and it didnt work either.
so tm im gunna try to use my dremel to get it out
just call me "Doc"
Check out my alero!
01-08-2011, 09:53 PM
Go buy a heat gun, if you try cutting it off with a dremel you're going to ruin it.
01-08-2011, 10:42 PM
where can i buy a heat gun?
how much do they cost?
just call me "Doc"
Check out my alero!
01-08-2011, 10:45 PM
⌘ Irish Pride
$20 for a Wagner dual temp gun at ur local home depot. i use it all the time and it peels paint off pretty easily
01-08-2011, 11:00 PM
out
this man is correct. you have to dremel the black piece of the bezel out and then silicone it back in. just take your time and be careful.
