07-17-2005, 05:51 PM
Ok,
I'm not sure if anyone else had this question, or just didn't know how to do it themselves.
I replcaed my factory radio, and got as new console mask.
I took everything apart just fine, but I should have removed my shift knob.
Now the lovres or slats that cover up the track for the shifter are out of place and just loose in the panel. I need to remove the panel to fix it.
It's just the 4 speed auto, with a leather wrap knob. Only thing I can see is a mettal tooth hidden below in the fornt. should it release if I push it in?
07-17-2005, 06:15 PM
yep, with a flathead screwdriver. Had to replace mine after my button broke =/
07-17-2005, 06:56 PM
yeah just pull it out and it comes right off. easy to put back on too
07-17-2005, 07:06 PM
just so there is no confusion. NO you do not push it in, and YES there is a metal clip that you must pull out. then the shifter slides right off
07-17-2005, 07:23 PM
its a pain to get in the first few times.. just doesn't seem to line up right. but then after the first hour of fighting w/ it, you'll finally get it.
07-17-2005, 07:33 PM
Its an automatic, and YES you push it in. Bite me =/
07-17-2005, 08:03 PM
An automatic that has the little staple looking F***er, that cherrington is right about being a pain to get back in needs to come OUT. Then the knob just slides off.
07-17-2005, 09:08 PM
um.....to get the shift knob off the stick/shaft you pull the pin/staple out of the knob.
07-17-2005, 09:40 PM
I think she was sayin u push it in to get it on...
But yeah damn, mine is missing....
2004 40th aniv. mustang
2006 kawasaki ninja
07-17-2005, 09:41 PM
i know you're from the backwoods or whatever. but i'll say it again.
yes it's an automatic, and to REMOVE THE SHIFTER. you PULL OUT the metal retaining clip.
better? i know you have trouble reading.
07-17-2005, 09:51 PM
I appreciate the input. I'll test it out and let you know how it goes.
07-18-2005, 11:41 AM
The problem is solved. It's a metal clip that keeps the shifter from coming off.
It pops out. I decided to try that first, seeing how I tried to push it in before.
Thanks for the input
07-18-2005, 12:01 PM
where can I get one of our pins from? Mine is missing
2006 kawasaki ninja
07-18-2005, 12:04 PM
I know some after market shift knobs come with it, I couldn't say which ones.
A dealership would probably have it. Most of the time they just put new clips in, and scrap the old ones. This goes for any metal clip or plastic fastener.
07-18-2005, 12:06 PM
no problem, i always like to give people the correct information, and see results when it works :heehee:
