Old 04-15-2008, 05:22 PM   #1
02Alero
02Alero's Avatar
02Alero is on a distinguished road
Send a message via AIM to 02Alero
Car caught on fire this weekend
one of the door unlock relays caught on fire and melted 2 other relays and a couple of fuses. why whould this have happened?
02Alero is offline   Reply With Quote
Old 04-15-2008, 05:37 PM   #2
AGT
AGT's Avatar
Karma?
Piss anyone off lately?
Exposed wire or constant power instead of remote?
Have a good day
Old 04-15-2008, 05:56 PM   #3
I could have not been fused properly..at least that is what the fuses stop from happening, or the wrong size fuse was used.
Old 04-15-2008, 05:59 PM   #4
spraying your electonics with gasoline?
Old 04-15-2008, 06:29 PM   #5
02Alero
02Alero's Avatar
i dont know what the hell happened i was driving down the road and my fuse box just started smokeing like crazy. so i pulled over and opened it up and one relay was completly fried and the rest were melted from the heat
Old 04-15-2008, 09:08 PM   #6
probably wasn't a fire... sounds like a REALLY bad short though.
Old 04-16-2008, 09:33 AM   #7
Yeap something was completely fused wrong causing one or all the wires connected to it to heat up.....hopefully you haven't damaged anything else but once you get it back up and going I would drop that fuse by 10 amps and see if it holds up, but that in essence isn't going to completely fix it unless you can figure out what is causing the problem in the first place. Like Cherry said you may have a short some where or the relay could have failed causing a short. Good luck on this one sounds like a bitch to figure out unless its an isolated circuit.
Old 04-16-2008, 01:47 PM   #8
Do you have anything wired out of the fusebox that could have bridged and cause the short?
Old 04-16-2008, 02:09 PM   #9
You may want to check to see if the door lock actuator in one of the doors is burnt up, may have been stuck on. Just a thought! Door relay usually runs around 15amps, and trunk should be about 10amps. Just a question, but do you have keyless entry? If so could it be possible that the lock/unlock buttons was pushed?
Old 04-16-2008, 02:47 PM   #10
02Alero
02Alero's Avatar
i do not have keyless entry and ill check and see about the door actuator and see if thats stuck or try and figure out if there is a short
Old 04-20-2008, 08:44 AM   #11
Daytona
ALEROMOD RAPIST
Daytona's Avatar
Daytona is on a distinguished road
It should say on the inside of the fuse panel what the amp should be for each item. Going too high or low will cause problems.
Daytona is offline   Reply With Quote
