09-13-2008, 11:46 PM
i'm currently working in a custom kit that will use your car a/c but not to cool the car... to cool the compressed air... gonna make a custom lower intake with the evaporator of the a/c that is in the dash incorporated to the lower intake of the car.... think it will work better than water to air intercooler setup since the new ''core of the intercooler'' will be like at 20* instead of like almost 100*... that's a try but I think it will work pretty good because the a/c never heats up and it ads no weight to the car..
09-14-2008, 12:04 AM
Sounds promising
09-15-2008, 04:08 AM
I think you'll find that it won't be able to keep up with the greater continuous air demand and higher temperature differential required by the engine, and also lower heat transfer coefficient. Not that it can't be done in principle, but I doubt it with the parameters of a typical auto AC system....
09-14-2008, 12:11 AM
except that the a/c produces drag on the engine
laminova does some weird stuff using a/c with their intercoolers though
09-14-2008, 12:52 AM
it takes what... 10 to 15 hp to get the a/c working maybe 20 maximum... if it gives me the chance to boots like 5 to 7 more psi(close to 20 psi of boost) i'm gonna have 500+hp so no big deal about a loss of 20hp that create 100....
09-14-2008, 01:09 AM
What about useing just the vent?
1999, RED Alero GX
09-14-2008, 07:52 AM
Maybe I'm wrong....(wait, no....that doesn't happen) but I'm pretty sure there's some things we need to look at here. Not saying show-stoppers...but:
1) GM programs in an A/C clutch cut-out above a certain RPM or TPS. (benefit)
2) Somebody is going to get kicked off the track for their car dripping (condensation)
3) torque stress on rotational components (A/C compressor/clutch?)
These things won't definitely happen, just stuff to think about....2 bad, 1 good
09-15-2008, 12:18 AM
Originally Posted by KenshinZero
That’s what i've read, but I have it in my head, that there is a way to use an intercooler, the factory intercooler of a 1st gen. Toyota Supra has both intake and exit tubes on the same side, and i'm guessing that it would work.
Uhh, the Supra wasn't turbocharged until the 3rd generation.
If you had the evaporator core as the intercooler, then most of the dripping would be happening INSIDE the engine. The core is what has most of the condensation on it.
09-15-2008, 12:25 AM
which would be fun in and of itself. OOOH...I got it, we could drill a big hole in the bottom of the supercharger or intake so the water wouldn't go into the engine.......ROFL.
09-14-2008, 11:16 AM
yeah i tought about the clutch thing... feed it with a relay when the key is on... water dripping. I dont think this is a problem personally..... for the torque stress .... I can hope its tough enough...
09-14-2008, 01:18 PM
hahaha I imagine the guy saying to his buddy :
" man I gotta reinforce my A/C clucth"
"Why?"
"because i want more boost out of my supercharger"
"WTF?! "
09-14-2008, 10:44 PM
HAH, Theres a thought.
1999, RED Alero GX
09-14-2008, 11:51 PM
yeah I know that but I mean with a working a/c system you know with r134a inside as refrigerant not just the compressor pushing air into the system... what I mean is a system that work like a air to water intercooler with the coolant grille incorporated to the intake spacer that bolt between the supercharger and lower intake... except it's refrigerant inside and not water, refrigerant can maintain a very much lower working temperature than water.... if I could I would have put a air to air intercooler, but I can't, maybe if I go twincharged one day with a GT42... but I don't think that will ever happen
09-14-2008, 11:58 PM
Boost Guru
I wasn't talking about that at all actually...
sorry yeah i re-read the complete thread, seems I missed a couple of post the other day... by the way, what will you do with your 2,4 turbo setup when you will be swapped... I might know a couple of interested people into buying all that
09-15-2008, 12:20 AM
inside the engine... but at the speeds air travel trough it will takes it all with it like vapors soo no problems
09-15-2008, 12:32 AM
at least the water would blow out real fast!
09-15-2008, 12:36 AM
my point is that with the heat inside the engine water will vaporize and what do you do when you spary alky ???? you spray a liquid into your engine
09-15-2008, 01:39 AM
Oh, that wasn't meant as a slam, I just thought it was funny. But spraying meth/alchy into your engine isn't the same, it's atomized as it's sprayed in, if done properly.
09-15-2008, 02:40 AM
Now, about the computer, instead of swapping it with a 2000 + Alero, wouldn’t it be possible to get one from a Cobalt SS? Considering the Cobalt is supercharged, the computer would be able to adjust the air/fuel mix, without buying a controller.
1999, RED Alero GX
Hybrid Mode
