Old 03-27-2010, 12:48 PM   #1
zr900lre
zr900lre is on a distinguished road
head tork
can someone tell me what pounds to tork the heads down
zr900lre is offline   Reply With Quote
Old 03-27-2010, 12:49 PM   #2
zr900lre
sorr its a 3400
Old 03-27-2010, 01:14 PM   #3
walkerj014
walkerj014's Avatar
walkerj014 is on a distinguished road
(Haynes reference: Chapter2, pg 2C-1) Cylinder Head Bolts:
Step 1:
1997 33 FT-Lbs
1998-2001 37 FT-Lbs
2002 and later 44 FT-Lbs
Step 2:
1997 through 2000 - Rotate an additional 90 degrees (1/4 turn)
2001 and later - Rotate an additional 95 degrees
Hope thats what you want?
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf."
2000 2.4L R1 concept Drilled and Slotted rotors WAI / Glow Gauge
walkerj014 is offline   Reply With Quote
Old 03-27-2010, 01:21 PM   #4
01silveralero
01silveralero's Avatar
44 lb ft + 95 Degrees
Make sure you make a x shape when doing the bolts. Go bottom right to top left over to top right back to bottom left then you can do the ones in the middle the same way.
Goal - Mid 11s all motor.
Old 03-28-2010, 07:37 PM   #5
zr900lre
thanks for the help i torked it 44 ft pounds and its all done and running i thought i did it wrong but i didnt i forgot to plug the alternator in and i had to give it some gas for the first start it starts right up once again thank for the help
