Old 04-04-2004, 08:30 PM   #1
IanJ66
First off here is the poblem.
Blew a fuse for the dash lighting, replaced the fuse and they worked fine, hit a bump and shorted out again (stereo wiring), fixed the wiring and replaced the fuse and nothing. Power on both sides of the fuse, headlight switch checked good, dimmer switch checked good, wiring diagram shows the LAMP DIMMER MODULE to be the next logical thing to check.
Question......WHERE THE F*** IS IT. I tore the damn dash apart, traced the wire the best i could and cant locate it.
Is it part of the body control module?
Has anyone ever had this problem?
Thanks for any help peeps.
Lata
Old 04-04-2004, 09:36 PM   #2
Aleromaster
Aleromaster is an unknown quantity at this point
Send a message via AIM to Aleromaster Send a message via Yahoo to Aleromaster
ok look at your dash.
look to the left.
See the ac vent with the dimmer knob?
there you go its on that panel. Pull it off and its part of the dimmer switch
2002 GL2 4DR, MYMODS:In dash 7&quot; VGA Widescreen monitor, XM Satalite Radio, Clarion Amp, 2 10&quot; Audiobanhn DVC Subs Hidden HitchTrailer Hitch, Grill Mesh
Aleromaster is offline   Reply With Quote
Old 04-04-2004, 10:00 PM   #3
Aleromaster
wow I just re read that and I came off sounding like an ass. Sorry din't mean to come off that way. I guess thats what 46 hours of no sleep does to you.
Old 04-04-2004, 10:01 PM   #4
IanJ66
If the module is part of the dimmer i feel stupid. However the problem may be elswhere. Checking the voltage at the connector of the dimmer i have the ground, power in when headlight switched turned on and variable voltage out. The green whire which leaves the dimmer and is supposed to then go to the module is hot and is the variable side of the switch.
