05-03-2007, 09:35 AM
two small problems
So I've been having some weird issues with the 'ho... Wondering if anyone else has had the same and if they know how to fix them.
1. Sunroof has dirt and junk in the tracks so it makes weird noises when opening/closing... just wondering what solution you'd use to clean it or if there's some sort of lubricant that goes in there.
2. Turn signals have a mind of their own. I'm cruising around and everything works fine. Then I go to signal and both left and right blink in the middle of the cluster really fast and then the signals quit working. After a few minutes they work fine again.
05-03-2007, 10:06 AM
*Raises Hand*
My turn signals have a mind of their own, they only work when they wont too never had they both go off like that but sometimes mine work and sometimes they don't
Live to Ride
Ride to Die
05-03-2007, 10:14 AM
My turn signal unit (I forget the more precise name) did the same. I had it replaced under warranty.
2001 2.4L GX 5 speed
05-03-2007, 10:18 AM
I wonder if theirs a recall on any of that
Live to Ride
Ride to Die
05-03-2007, 10:20 AM
I doubt it... atleast not for the 02's in Canada.
05-03-2007, 10:21 AM
I'm in Florida mines a 01 know of any recalls?
Live to Ride
Ride to Die
05-03-2007, 11:33 AM
i think that may be associated with the hazard light recall done on most of the vehicles. Look into it. As for the sunroof track i would just clean it with brake cleaner and q tips. I use brake cleaner for everything, its amazing. Then maybe a light coat of wd40 to lube it?
05-03-2007, 11:47 AM
yep its the hazard light button
05-03-2007, 12:23 PM
my sunrrof started doing that, then one day it would not close on one side, apparently it is off its track, and when i did get it shut, it would not open...that was 2 years ago...still shut and wont open
OCA Alero Chapter Member!!!!
ALERO-LESS
05-03-2007, 12:26 PM
I Have ONE NUT
Yep, common problem.
05-03-2007, 12:58 PM
^^ hehe i have it i just never got a chance to replace the hazard switch
05-03-2007, 01:29 PM
hazard switch is a recall as it could potentially be life threatening
05-03-2007, 04:15 PM
well talked to the stealership this morning.... no recall on my car...
how hard/expensive is it to replace the switch?
05-03-2007, 05:56 PM
Supposedly easy but I couldn't get mine out.
??,??? km
??,??? miles
