12-10-2010, 12:50 AM
Need some tire help...
I have a set of 17 by 8 rims and I need a set of tires. My question is if a set of 235/55/17 tires fit without fittement issues? I'm currently running a set of 245/35/19 with no issues.
12-10-2010, 01:07 AM
They'd be a little tall... I run a 235/45R17
12-10-2010, 03:33 AM
You will have a little sidewall stretch but the overall hight of the tires will make up for it.. it will work
12-10-2010, 04:37 AM
12-10-2010, 08:01 AM
Wont work at all..you gonna rub in the struts with that diameter, unless your wheels are sticking out the fender. trust me
12-10-2010, 08:04 AM
^x2. I got a set of 235/55-17 michelin pilot sports through work and they rubbed on the bottom of the spring perch. swapped them out for some 225/50-17's and they dont rub one bit.
12-10-2010, 10:21 AM
Thanks, I dodged that bullet... What about 245/50/17s? Also, would a 19" snow tire even be effective?
12-10-2010, 11:33 AM
you have to remember tire sizes are aspect ratios. the wider you go the taller the side wall also gets. the sidewall is a certain percent of the overall width of the tire. i would almost bet they would still rub but it would be close. why a 50 series? why not 45?
12-10-2010, 11:37 AM
This is a great resource, stock size is 225/50/16
http://www.miata.net/garage/tirecalc.html
245/40/17, 235/45/17, and 225/45/17 are all very close to stock diameter, although 225 is getting a little narrow for an 8 inch rim.
1987 Honda Rebel 450
12-10-2010, 04:58 PM
255/40/17 or go home.....lol
12-10-2010, 05:10 PM
lol buy a set of steelies and 15 inch tires of 195/65r15 winters and your good to go remb a wide tire is ridiculous in the snow on such a small car your better off with the size I mentioned ( for winters )
12-10-2010, 05:53 PM
255s really aren't that wide, there are plenty of cars with that wide of tires, besides, I went through a entire colorado winter on 255 tires, it wasn't that bad.....
12-10-2010, 07:02 PM
I need a semi tall sidewall. These Chicago pot holes are a real b!tch... I lost three tires and one rim in a matter of seconds... And this was on 35 series tires!
12-10-2010, 07:19 PM
Just get some 225/45/17
sorry didn't realize you have 8" wide rims, 235/45/17 would be good then
12-10-2010, 08:11 PM
I agree......go with the 235/45/17 you will be happy with that size tire, that is what I run on the rears of the alero.....
12-10-2010, 09:01 PM
kwhauck I live in an area of canada that has snow and ice most of the year, I couldn't imagine driving with a wide tire and not getting stuck somewheres
12-11-2010, 06:00 PM
If i lived in Canada I would just drive a sierra duramax/allison year round....
