12-24-2007, 10:54 PM
How much of a pain is the waterpump?
My waterpump shot craps on me today. How much of a pain is it on an ecotec? I just hope its nowhere near as bad as the 2.4L. Had to tow the stupid thing home today, wasn't terribly happy about that.
Sucks ass because I have an early flight on Christmas morning, and I wanted to leave the alero at the airport versus taking a taxi or leaving another car there.
12-25-2007, 02:41 AM
- If equipped with an automatic transmission, remove the exhaust manifold. Refer to Exhaust Manifold Removal in Engine Mechanical - 2.2L (L61).
- Drain the cooling system. Refer to Draining and Filling Cooling System .
- Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
- Remove the right front tire and wheel. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
- Remove the front fender liner. Refer to Front Fender Liner Replacement in Body Front End.
- Remove the access plate on the water pump sprocket from the timing cover.
- Install J 43651 to the water pump sprocket.
- Use the access plate bolts to secure J 43651 to the engine front cover.
- Remove the bolts that secure the sprocket to the water pump.
- Remove the bolt (1) that secures the engine block to the water pump.
- Remove the bolt (2) that secures the engine front cover to the water pump.
- Remove the feed pipe that joins the thermostat housing to the water pump.
- Remove the 2 bolts that secure the water pump to the engine block.
- Remove the water pump.
12-25-2007, 03:29 AM
where did you get that from? GM SI????? I hate that program, they always refer you to other shit..... lol
12-25-2007, 03:38 AM
but it's always right...
12-26-2007, 12:51 AM
Owner
^^ yes it is
Beware of the BackStabber
12-26-2007, 01:59 AM
Doesn't sound too bad, I'll check into it more when I get home. I only looked at it for like 2 seconds when it shot craps on me and it looked like it was going to be only slightly annoying.
Probably right around the annoyance level of doing a thermostat on the 3400.
12-26-2007, 05:31 PM
as far as water pumps go.. its not too bad.
It gives 4 hours labor, but the pump itself is a lil bit pricier than some
Not as bad as the Dodge 2.7 v6 motors. Theres one in now thats nearly 6.5hrs labor. def a PITA
12-29-2007, 11:33 PM
Only took about 3 hours to do, but that was with a heavy amount of screwing around. Certaintly not as easy as what I work on at work on a daily basis, but it was nowhere near as hard as the water pump I did on my friends 93 300zx.
12-29-2007, 11:48 PM
LOL, i know, but theres too much shit to click on, they need to have everything on one page
