09-20-2009, 09:46 PM
problem with the power steering
the power steering fluid is leaking from somewhere were do you guys think it could be leaking from?
09-20-2009, 09:51 PM
On mine, it was leaking from the underneath the Powers steering reservoir. Can you see the fluid or are you just noticing a decrease in fluid from the reservoir?
09-20-2009, 10:37 PM
If it's not coming from the pump it's porbably a p/s pressure hose
09-20-2009, 10:39 PM
Canada's Ghost
X2 its most likely a pressure hose
09-20-2009, 11:03 PM
Ok what if your power steering has like knots in it and im not losing power steering fluid???
09-20-2009, 11:04 PM
haha how in the hell did you get knots in your prussure hose?
09-20-2009, 11:11 PM
Maybe he just wanted to say that his ps pump isn't pumping, like mine
09-20-2009, 11:13 PM
no theres no knots in the hose but like when im driving everyonce in a while ill be turning and then it gets super hard to turn the wheel, (and the best thing i can describe it like is like driving an old school tractor without power steering,) but when i start to get the RPM's up it becomes easier to steer?
09-20-2009, 11:15 PM
either you need a power steering pump or a rack and pinion - or you could just have some air in the lines
09-20-2009, 11:17 PM
Are any of these things serious? because i have brought it into the shop and the guy just told me to watch my fluid level and the level has been fine now for the last 6 months???
09-20-2009, 11:19 PM
a rack and pinion is pretty spendy - does it whine ever when you turn the wheel
09-20-2009, 11:22 PM
sometimes
09-20-2009, 11:23 PM
I was just gonna ask. Sounds like his pump is about to go. You can get a new pump for a decent price off eBay. New ones are pricy, especially those for 3.4 with variable assist.
09-21-2009, 01:13 PM
So I found ok the car-part.com website that a used power steering pump is $75
09-21-2009, 08:57 PM
hey guys i check the pressure hose and it doesnt look like is leaking from there... so could the power steering be leaking from RACK AND PINION???
09-21-2009, 09:39 PM
Check the rubber boot sleeve that goes over the steering column gear leading into the rack. Mine had come loose and the fluid was leaking like crazy, but I slipped the rubber boot back into place and it stopped leaking completely.
09-21-2009, 09:41 PM
i hope is that ty for the help
there is still hope... i hopes is that
09-22-2009, 09:57 AM
mmm... the rubber boot it has a nice hole.... and the fluid is leaking from there so how do i change that?
09-22-2009, 10:14 AM
You'll have to disconnect the steering linkage, it might be a 13mm bolt I don't remember. You'll have to get the car in the air, and its probably the first steering knuckle above where the column leads into the rack. I don't remember for sure how to do it, but chilton has a good website:
http://infotrac.galegroup.com/menu?db=CHLL
Reason: website
09-22-2009, 08:09 PM
should i take it to the mechanic or try to do it myself????....
