03-18-2007, 09:36 AM
Long term effect of lowering
I have been thinking about lowering my car, but I was wondering if there were any long term NEGATIVE effects of doing this.
Like will I shorten the life of my brakes, ball joints, CV joints, or other steering components.
TIA
"J"
02 Bronzemist Alero
DetailCity.org - Supermod ... Join the obsesion
03-18-2007, 09:59 AM
I'm going to say that that stuff shouldn't be affected. I have no real experience with it, but theoretically, everything should be fine.
Because when you lower a car, you change how the body sits on the strut. So all of your suspension should keep the same geometry. If it were a car with a Double A-arm, then the suspension geometry changes, but on a car with struts, I really cant see it being an issue. All four struts go straight up and down and support the weight of the car.
03-18-2007, 10:38 AM
struts will wear faster
03-18-2007, 11:35 AM
As Paul said, struts will wear faster, and in addition, depending on how drastic you lower the car, the changes made to the geometry affect tire wear aswell. If you do intend on lowering your car, make the necessary supporting mods aswell IE: Camber adjustment bolts.
03-18-2007, 12:46 PM
one nagative effect is you have to becareful with speed bumps and driving up into parking lots and stuff. try to hit most of them on an angle. struts will wear out faster and also camber angle. also becareful when you park in a spot with parking blocks, don't be afraid to leave some room in front of your car or you might eff up your bumper.
01 Alero GX 3400 swapped
v8 swapped 84 s10
03-18-2007, 01:15 PM
In the long run you will have a lot less plastic underneath the front of your car. Mine gets ripped off little by little since I lowered it.
03-18-2007, 01:21 PM
Camber kits. Are they necessary for 1 inch drops or can the Alero be alligned for a Eibach Pro kit drop? From what I understood, if you went 2+ inches more, you'd need the camber kit.
??,??? km
??,??? miles
03-18-2007, 01:50 PM
when i bagged my car i had to be crazy carefull not to kit Parking blocks, curbs ect... ur so low u forget to check clearances and WHACK , then ur swearing uP a storm in the car. lol
03-18-2007, 06:23 PM
V.I.P. Punching Bag
hahaha been there
at my brothers place he has an underground parkade and my god that thing is on a terrible slope, i nailed my effing muffler for crap sakes!! but bumper too a hit getting in and out!!
03-19-2007, 06:56 PM
if its the same as my grand am it will eat your upper strut mounts
03-19-2007, 08:28 PM
Thanks for all the input everybody.
I will have to weigh out the pluses and minuses on this one
"J"
02 Bronzemist Alero
03-19-2007, 11:10 PM
Its worth it man just do it if you have the $$
2004 40th aniv. mustang
2006 kawasaki ninja
03-20-2007, 06:17 AM
I just did mine with Eibach Pro series and I love the look and the ride.
Eibach pro series springs, 18" Forte F5 wheels, Kelly HP tires. More to come.
