Old 01-06-2008, 10:40 PM   #1
HotRod11686
HotRod11686's Avatar
HotRod11686 is an unknown quantity at this point
Springs and Struts Upgrade
Ok so I am finally upgrading the springs / struts on the ho and after reading all the threads im gonna go with the KYB GR2 struts and for springs im getting Sprint springs.
Now my question is:
What else do I need to complete the strut upgrade. I need the strut boot and strut mount. Is there anything else im missing from that list? Also can someone give me some help as to exactly what strut mount and boot I would need for the KYB's. A link to an ebay auction would really help me out.
Lastly I would like to ask about installation. Is it hard enough to do that I would have to take it to a professional or would I be able to do it with the right tools. Does it require removal of any other components in order to replace the strut, etc.
Any and all information is greatly appreciated.
Thanks again
ALL PARTS MUST GO!!!!!
HotRod11686 is offline   Reply With Quote
Old 01-06-2008, 10:51 PM   #2
you can re use the upper strut mounts, stock ones dont get chewed up too bad if you've had stock springs and struts.
Old 01-08-2008, 02:25 PM   #3
spend a little extra and get the KYB AGX struts
Old 01-10-2008, 10:04 PM   #4
HotRod11686
are they worth the investment?
also
I wanted to ask if dropping using the Sprint (1.75" front/rear) would be ok with my 18" rims or would that be a problem?
Old 01-10-2008, 10:39 PM   #5
you'r able to drop ~3 inches with 18s without rubbing and yes, i would invest the extra money for the AGX's
Old 01-11-2008, 03:41 PM   #6
Vinalero
Vinalero's Avatar
AGX are cheaper than GR2 on pfyc lol
Old 01-11-2008, 08:30 PM   #7
AJules
AJules's Avatar
AJules is on a distinguished road
I highly doubt that
show me
AJules is offline   Reply With Quote
Old 01-11-2008, 10:14 PM   #8
Rexter9x
Rexter9x's Avatar
Rexter9x is on a distinguished road
You gotta remember, the $269 is for 2 agx's, not 4 like the $272 for the gr2s
Rexter9x is offline   Reply With Quote
