Old 10-20-2012, 10:58 PM   #1
irondiezl3
irondiezl3's Avatar
pick between these 2 drums please.
if you look closely the bendix dont say china and the delcos do i heard the usa drums are alot better idk hope you can help me pick.
http://www.ebay.com/itm/ACDELCO-ADVA...72be31&vxp=mtr
or
http://www.ebay.com/itm/BENDIX-PDR04...194297&vxp=mtr
Old 10-20-2012, 11:10 PM   #2
comanche
comanche is an unknown quantity at this point
If I remember correctly, ACDelco Advantage and Bendix Global are both economy drums. Someone else might know more about this though...
That said, I've never had a problem with cheap drums, provided the proper friction material is used. High performance shoes should have high performance drums.
comanche is offline   Reply With Quote
Old 10-20-2012, 11:43 PM   #3
irondiezl3
irondiezl3's Avatar
or are these better?
http://www.napaonline.com/Catalog/Ca...445_0325244781
Old 10-21-2012, 10:40 AM   #4
or convert to disk
Old 10-21-2012, 11:39 AM   #5
irondiezl3
irondiezl3's Avatar
i always wanted to convert to disk i wish i knew how.
Old 10-21-2012, 01:26 PM   #6
RalphP
RalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond reputeRalphP has a reputation beyond repute
Easy enough.
Basically, you swap everything strut down from a donor car, including the parking brake lines.
Here's a discussion on using Alero disc parts on a 2000 Malibu - amazingly, you could use Alero hoses (which the Malibu can't!) since *ahem* your body plumbing is just like an Alero
http://www.chevymalibuforum.com/foru...ad.php?t=10765
Alas, the two Malibu sites that had that information? Are offline.
And no, I didn't keep pics of my Malibu conversion.
I'll suggest again that if you're doing this, do new struts in the back also. That means only the two cross rods, the sway bar parts, and the trailing arm is left, all else is new.
If you were nearby, I'd offer to let you park your car next to my Malibu and we could swap before I had the 'Bu picked up for a relatively small consideration - these aluminum motors don't take to overheating well (and I had a surge tank blow at 75MPH on a 104F day ... by the time I got to the side of the rode, it had quit, and has not run since. Alas. But since it had over 330Kmiles on the factory motor, I decided it was time to let it retire.)
RwP
RalphP is offline   Reply With Quote
