04-19-2009, 09:37 PM
#81
Canada's Ghost
as long as you got it all over the filter and don't have any bare spots that didn't get any oil one them your good to go
04-19-2009, 09:51 PM
#82
The Aleromod PITA
ok i dunno know if its the new wheels or the air intake that makes it feel slower on easy throttleing but i love this products boost with full throttle
thanks though your a big help
04-19-2009, 09:59 PM
#83
Canada's Ghost
no problem, it's debatable with the results you will get with such a small mod I really noticed a difference in passing gears with my intake which actually surprises me cause I knew the gains would be so minor that they would be un-noticable.
04-19-2009, 10:39 PM
#84
The Aleromod PITA
the sound is more encouraging then anything
04-20-2009, 10:00 AM
#85
I find the throttle response to be alot better.
04-20-2009, 11:21 AM
#86
The Drunk
Mines in the mail, picked up a blue cosmo. (if you want red or blue just get the GA one and deal with the bracket) I'm not a car wiz but I can see the throttle responce being better. As air goes in it goes straight as you increase speed. With stock air gets bounced around to decrease noise. As you increase speed you're pushing faster air into a contraption designed to slow and redirect air into happy acustic shushing sounds. That's my stupid logic.
Course like everything there's cap to that. So I understand the couple hp gain. I've heard a lot of people like me say woot I can spin the tires finally. Am I right in assuming intake helps a lot in the low end, off the line type power and less as you're getting to constant speed?
Also, I'm from cali so ignore the side effects of raining **it on my wai, how far can I go porting cold air to it? Damn it from a cai pipe? Or enclose the whole thing in pipe bigger than the filter? Or will that just violate the filter?
`03 Alero GL 2.2L Ecotec
04-20-2009, 12:15 PM
#87
The Aleromod PITA
if your car didnt already chirp tires, its worn out, mine chirped all the time with out it, what size tires r u messing with these 225 dont break loose as easy as the 215's
10-24-2009, 04:09 PM
#88
can someone help me out on a short ram for a 3400
10-24-2009, 04:15 PM
#89
im in miamisburg not far from you... all you need to do is run a short pipe (not even really neccessary) from the maf and put on a filter... easy.. run it to the fender well like mine
10-24-2009, 08:39 PM
#90
/\/\ aaah! zombies!!!!
10-24-2009, 09:23 PM
#91
I commend him for not starting a new thread.
