10-15-2009, 12:41 PM
#41
i believe they sell either the bearing for it or the entire assemb.
10-15-2009, 01:24 PM
#42
You might be able to disassemble the tensioner, but it's not generally a serviceable part. I think what you can buy is either the whole assembly, or just the pulley. Maybe it's the bearing like Gr1m said, but I think it's the pulley that's available. So you would have to get a used tensioner, and it really wouldn't be worth the trouble. Not to mention, getting it back together and being certain that it's reliable would be difficult.
10-15-2009, 01:28 PM
#43
You can't replace the bearing in the (plastic) tensioner pulley. You can however replace the bearing in the two (metal) idler pulleys. (Timken #203FF)
10-16-2009, 03:43 PM
#44
y dont u just get a belt tentioner tool? like 50 bucks
11-01-2009, 09:19 PM
#45
Its Beer Thirty
Good info there Cliff. I changed out both of mine today. One of them was making a squeeking noise anytime i was over 1000 rpms. 11 bucks for the two bearings, they wanted $17 for one idler pulley. Someone sticky that info please.
Originally Posted by Daytona
11-23-2009, 12:08 PM
#46
I finally got around to changing out this belt. I've only driven the car twice since I put the belt in, but so far no squeaking. The old belt had a lot of cracks in it (on the inside part). Was worse than I had expected, given that it only had 26,135 miles on it.
11-23-2009, 12:16 PM
#47
it makes it so much easier.
Originally Posted by adam337
Goal - Mid 11s all motor.
11-23-2009, 12:31 PM
#48
those inside cracks are what matters when you are visibly inspecting the serp.
Mine was replaced 3 years ago, maybe drove 100 miles since and just from sitting it has cracked, and i will need a new one soon....but no sound as of last time I drove it (month ago)
11-23-2009, 12:42 PM
#49
I thought about posting a picture of the belt, but I'm sure that you have seen something just like it. Slightly worse than this one I found on the internet:
11-23-2009, 12:45 PM
#50
yup typical wear and tear cracks.....i beleive those cracks are what causes the squealing
11-23-2009, 05:39 PM
#51
So here's an on-topic question while we're discussing belt lengths. I went to find a new belt for my 2003, and the guy behind the parts counter asks me if it was "early or late design". Apparently there are two different lengths for a 2003 V6, one is 8.7" and the other is 8.64" How do we actually determine proper belt length? I told the guy that with a tensioner, either one would likely work. How do we know?
11-23-2009, 11:45 PM
#52
I believe they changed the alternator in mid '03. Possibly the bracket too.
11-23-2009, 11:49 PM
#53
well, I'm about to drop in the FFP UDP, and it would probably be a good idea to know what size I'll need, LOL
11-24-2009, 07:34 PM
#54
take a string and run it around the pullys like if it was stock ...
take it to a parts store and check the string on the belt checker to find your belt size...
BUILDING A V8 ALERO 2DR
11-24-2009, 09:44 PM
#55
good idea.
11-24-2009, 10:03 PM
#56
How does that work, if the belt is off, isn't the tensioner at maximum extension?
11-24-2009, 10:20 PM
#57
dammit. bad idea. I'm so confused...LOL
11-24-2009, 10:30 PM
#58
You can get different diameter idlers, 3.5 and 3.25 off cars at salvage yards, too. That's what I did when I changed to smaller SC pulleys. That's for swapping the lower idler. Mid-90s Taurus has a 3.25 that fits, iirc....Also, I have found different diameter tensioner pulleys on replacements sold at Autozone.
11-24-2009, 10:41 PM
#59
I'm just going to measure the intact belt I have now, and get 1.5" shorter.
