Old 04-18-2010, 02:48 PM   #1
zzyzzx
zzyzzx's Avatar
How do I get the coil pack off?
I don't see how it's possible to remove the nuts on the back of the plate. It seems difficult, but possible to get the one on the alternator side using a 13mm wrench, but the one on the master cylinder side I have no idea. The cabling seems to be in the way. It does not seem to budge, if it was movable, I could probably use a ratchet.
Old 04-18-2010, 03:21 PM   #2
I reached down behind the coils, and put a deep well socket on, with my hand in the open space behind/under the coils.
Also look for any little plastic clips that might be holding those wire packs in place.
Old 04-18-2010, 03:43 PM   #3
zzyzzx
zzyzzx's Avatar
OK, I got it off. sems to me the trick is to undo those wiring clips, then manhandle the wiring harness pieces until you can get a deep welled socket in there.
Old 04-19-2010, 12:57 AM   #4
I had no problems with this:
1/4 drive rachet, small extenion bar, 5.5mm socket (not a deep)
Did all 3 in work's parking lot in 25 minutes
