08-16-2009, 11:17 AM
Plugs
Im sure there is a thread already but i cannot seem to find it but what are the best spark plugs to run in the 3.4? I am having a misfiring problem from #4 and i have read on here that changing plugs helps.
2003 Alero GLS 3.4L
08-16-2009, 11:34 AM
ac delco iridium.
08-16-2009, 11:36 AM
Originally Posted by jackal2000
ac delco iridium.
or AC Delco Rapidfires, iridium FTMFW though
08-16-2009, 07:49 PM
I'm running rapid fires right now.
Still missing a bit, but I was told I new new wires, and my number 3 plug looking a bit white
probably going to new new coils soon
08-17-2009, 01:31 AM
ac delco iridium.
FYI, They're #41-101
08-17-2009, 02:03 AM
What about these new "pulse plugs"?? http://www.pulstar.com/ Are they any good?? Do they perform the same?? Do they damage the vehicle in any way??
10-01-2009, 11:20 PM
Also, what about the E3 Diamond fire spark plugs???
10-02-2009, 02:20 AM
I have E3 plugs in my alero and they work great. no problems so far.
10-02-2009, 02:31 AM
I would never pay the amount of money those plugs cost to even try it
2003 GX Coupe: 2.2 ecotec, CAI, Header, High Flow Cat, Catback Exhaust System, Cleared Corners, Tinted Tails, 8000K HID's, Reverse Glow Gauges...so far
10-02-2009, 06:36 PM
the pulstar are a total waste of money imo. the ac delco iridiums are your best bet, but whatever you do, NO BOSCH!!
10-02-2009, 06:55 PM
Pulstar plugs are not worth the money, but they do work, a little.
Multiple electrode plugs are a waste, the spark will take the easiest route, it's not like you're going to be having multiple sparks (one to each tip) or anything.
NGK all the way.
10-02-2009, 10:22 PM
NGK and Ac-delco have a share with each other i believe....or they did at one point.
i remember i had some AC-delcos that had "NGK" engraved on them...... now the new ones say "parts from japan"
10-02-2009, 11:15 PM
Why do we still post answers to these threads? I can't even count how many times this question has been asked. Use the damn search button.
10-03-2009, 01:44 AM
ngk pretty much builds the acd plugs. ngk is a japan made plug, so if it says that on the acd plug its probably made in a ngk factory.
10-03-2009, 09:12 AM
I had bosch but I think that Ac delco rapid fires are the best
10-03-2009, 02:44 PM
^bet that about after a month it started running like shit and no power with the bosch though. thats a common problem when they are put in lots of gm vehicles for some reason.
10-04-2009, 02:47 PM
It has to do with the single platinum plug and a waste-spark ignition system. It wears the plugs unevenly. The bosch design tends to exaggerate the effect.
10-04-2009, 04:14 PM
what would some of these crappy symptoms be? I have bosch wires on my 3.4 and have gotten some stuttering starts.
Sorry to thread crap/jack but I never thought to chekc on this before.
SOLD - 1999 GL Sedan-LA1 3400
Installed - CAI, drilled and slotted rotors w/ Carbon fibre brake pads.
OWN - 1996 Rover 414 - replaced engine with a 1.7TD Isuzu lump and gearbox, Uprated brakes, Custom seats and interior trim, MG ZS 11 spoke wheels, Custom bodywork, Custom LED taillamps, Custom gauge surround to hold 2 52mm gauges (filled with boost and oil pressure gauge)
