12-05-2009, 07:53 PM
help!
my lows and highs are on but my highs are dim along with my passenger side low
12-05-2009, 07:57 PM
Is that on your dashlights???? or headlights?
BUILDING A V8 ALERO 2DR
12-05-2009, 08:04 PM
headlights
12-05-2009, 08:06 PM
i had hids in but the one on the passenger side went out changed the ballast and the same thing but then i swaped out the hids for the halogens and the hi's were dim
12-05-2009, 08:16 PM
Originally Posted by dhurst765
i had hids in but the one on the passenger side went out changed the ballast and the same thing but then i swapped out the hids for the halogens and the Hi's were dim
the K's are different...
example your hid are 5k and the highs are 6k..
If you swap it for a 5k then that could be your problem or you could have a bad light.
are you running full HIDs ? if so then you need to ck with you shop or where you brought them from...
12-05-2009, 08:24 PM
i had hids in my lows and halogens in my highs my drl are on my lows but i disabled them. but i put the halogens in my lows that were stock and they did that
12-05-2009, 09:35 PM
all i can think of a possibility is a bad wiring connection. Thats a really weird and random problem.
12-05-2009, 09:55 PM
Defeat < Giving Up
You need a relay on them if you dont already have one.
WhiteLiquid
12-05-2009, 11:08 PM
^x2, but i just figured he knew that just out of common sense. You need a relay when doing that mod, can't just wire them straight together. Plus you would never have just lows without a relay.
12-06-2009, 02:32 PM
r u talking about my hids cause they were just a plug and play se
12-06-2009, 03:52 PM
^um lets get something straightened out, when you say lows and highs on, do you mean at the same time or are they still separate? I was thinking same time the way you had it worded, but apparently not, so you don't need to worry about the relay comment you don't need one then.
So, you're saying that even when you put ALL halogen back in they still were dim? I'd check for a melted area on your harness then. But other than that i was just gonna say your hids are starting up right. That happens on mine sometimes, one won't turn on or it'll fire but stay dim. but i just turn them off and back on and they start working right.
12-06-2009, 04:28 PM
nevermind i figured it out it was a fuse
