Old 04-29-2010, 04:07 PM   #1
Alternator problem?
Hey sup guys long time no talk... ok well I was driving a couple days ago and all my lights started dimming and all the dash lights came on and stuff so I guess I'm just double checking its the alternator before i pull it off cause yea serpentine belts suck
Old 04-29-2010, 04:41 PM   #2
Run a load test.
Old 04-29-2010, 04:56 PM   #3
our serps are easy.... REAL easy.
Old 04-29-2010, 06:33 PM   #4
broken__one
broken__one's Avatar
broken__one is on a distinguished road
check that batt. too, mine did the same thing when the batt. took an ish.
broken__one is offline   Reply With Quote
Old 04-29-2010, 07:39 PM   #5
Take it to Autozone or Advance and have them test it in car.
Old 04-29-2010, 08:02 PM   #6
Afugy
I poop alot
Afugy's Avatar
Also check your grounds off the battery, where the battery grounds to the body of the car is not in the greatest place. Just check all connections coming and going to the battery.
Old 04-29-2010, 08:08 PM   #7
zzyzzx
zzyzzx's Avatar
Install a voltmeter and tell us what you see with it running and not running.
Old 04-29-2010, 09:23 PM   #8
alerogls001
alerogls001's Avatar
alerogls001 is on a distinguished road
Mine doing that when I turn ac on and lights are on. I'm gonna have them test it at autozone and buy a alternator only if I need it. My battery is from them and still under warranty. I'll tell u what they say on mine.
MP Racing CAI, Pacesetter Exhaust, and PCM. High flow CAT. KYB GR2 struts. Canuck Motorsport Springs. Cross drilled rotors. Stern ST18 17" rims.
alerogls001 is offline   Reply With Quote
Old 04-29-2010, 11:26 PM   #9
Your car hates you, esp if you think the serpentine belt is hard to do
Old 04-30-2010, 08:59 AM   #10
zzyzzx
zzyzzx's Avatar
If I were made dictator, I'd require that all new cars have a voltmeter installed. For now just go to WalMart and pick up one of these:
Equus 3721 Battery and Charging System Monitor
Old 05-02-2010, 10:25 AM   #11
alerogls001
Well I wont be much help. I had them test mine and the battery and alternator came up clean. But showed a bad starter.... decided to wait for next weekend to replace it and lo and behold I got stranded in a parking lot with the kid last night. Got it finished and home by midnight. Ughh.
