04-18-2011, 08:41 PM
#21
to be unique
04-20-2011, 11:18 PM
#22
not just to be unique but it would just be sick for autocross and track days and such... plus come on... would you rather have an AWD Alero or a RWD Alero..
04-21-2011, 12:36 AM
#23
15.65 @ 87.3 MPH
Depends on where you live and the application. At the track, RWD all day everyday. On dirt or snow AWD > RWD. I do agree if you do autocross, an AWD set up would be awesome. Since my Alero is my beater I would rather go AWD rather than RWD, but if it was summer only than RWD would be better. But then again if you want an AWD car then buy one. It probably would be easier. Thats just my opinion.
04-21-2011, 12:58 AM
#24
Originally Posted by zzyzzx
Besides reduced gas mileage and increased maintenance costs, what's the point of having a 4wd car?
good in snow a awd car is better in the snow than fwd and better handling. why do u think subaru's are so popular.
04-21-2011, 12:59 AM
#25
awd
04-21-2011, 01:50 PM
#26
why buy one when you can make one
04-21-2011, 02:24 PM
#27
An intersting mod if anyone could pull it off. it would be alot of wrench time that for sure
I am beyond help...
04-21-2011, 03:08 PM
#28
It wont be done....he will get overwhelmed by the amount of work needed and give up 1/4 of the way through. Wasnt it not so long ago that you couldnt even complete the door panel mods? Good luck
04-21-2011, 03:33 PM
#29
I have witnessed a 3rd gen Civic being turned into a RWD by one of the autocrossers in my region... what a failure... the car handled much worse as the weight distribution and chassis for a fwd and rwd are very different. I have however seen people turn AWD cars to RWD with good results.
GS - 01 Alero Coupe - MT, CG-lock,Front/rear strut tower brace,WAI,Fidanza Short throw Shifter and custom short throw clutch, AGX adjustable struts and mounts, Dropzone Springs, speedbuilt front sway bar, Toyo R888.
CS - 06 RX8 - Special Edition Shinka, 285 Hoosier A6.
04-21-2011, 04:33 PM
#30
I dont even know what the door panel mod is so I obviously never tried it.. you have me confused with someone else. Nice try on trolling though. And I never said I was going to or would ever do the AWD swap I'm just bringing it up as something someone else could look into.
04-21-2011, 04:36 PM
#31
If you could distribute the weight properly I would MUCH rather see a mid-engine ls4 swap out of an impala SS...but hell, if you get started on awd I'd probably drive all the way out there to give you a hand..
09-02-2013, 02:40 AM
#32
Well... looks like this azteck awd swap as actually done to a grand am concept called the autocross concept or whatever... a little info here.. so it was a 5 speed turbo 3500 swap.... the eff
09-02-2013, 03:21 AM
#33
Here you go.
Originally Posted by Oldsnut
Originally Posted by tipnitty
09-02-2013, 04:04 AM
#34
RWD Alero any day, everyday. Why? Because; eff front wheel drive, eff anything that makes the steering wheels be the drive wheels, eff anything that can't do a proper tire eating burnout. Maybe a bit extreme, but I digress... My point is valid, AWD may have many benefits than RWD, it damn sure has more benefits than FWD but you can't hoon an AWD car without breaking half the shit in it. AWD cars are too delicate to have fun with. You can't J turn them, you can't burn out in them, you can't make the front end jump (not that an RWD Alero would ever be able to), basically you have to tune your driving to the car's 4 wheel drive system. Sure you can make it handle like a boss at the autocross or you can do figure 8's but still doesn't beat the fun of driving an RWD Car.
Actually, this has been brought up before, by WIAlero.
http://www.aleromod.com/forums/showthread.php?t=37162
But anyways, routing the driveshaft isn't the hard part... since the Aztek was FWD based (meaning it was transverse mounted with a preference to the front wheels), the driveshaft wouldn't be that humongous pipe running down the center of your good ole Caprice Classic. It would actually be a skinny pipe going to the back, if that since apparently, GM didn't exactly use a propshaft. Now the real problem would be adapting the Aztek's rear suspension to the Alero. The Aztek is on the "U" platform, which shares NOTHING with the "N" platform, other than the 3400 engine. Adapting the AWD trans is nothing to adapting the rear end, and you would need the whole rear end. The good thing is that it's not a solid axle just how the "N" body is, but I doubt anything can swap over.
http://auto.howstuffworks.com/pontiac27.htm
Here's a site that gives you some hints as to how the rear end of the Aztek is set up. It's doable, but everyone that says it would have a rear end preference is wrong... the end result would still be a FWD Alero with an assist, similar to the 90 Prelude that could steer its rear wheels when making sharp turns or whatever they said it did.
1994 Olds Cutlass Supreme
1996 Infiniti G20
1993 Chevrolet Lumina Z34
1989 Buick Regal Limited
09-02-2013, 10:11 AM
#35
dude... check the time stamp... this thread is over 2 years old... eric actually brought it up before wialero...
09-02-2013, 12:14 PM
#36
Pretty sure I linked him to it as well lol... and I know how it works... if you had read the whole thread you would know that
09-02-2013, 09:53 PM
#37
My bad foymund out how to use search after that
2004 olds alero R.I.P 242,500
1995 f-150 5.0v8 5sp 143,xxx(redneck truck)
Now searching for a new Ho!
Originally Posted by Redog
He no crazy, he WIALERO!!
09-02-2013, 10:08 PM
#38
Dude your fine wi. nas just callin me out over something I know a lot more about like I'm jigga. Pssh son didn't you learn from got myself a gun
Totally joking tho nas - ether is the greatest diss song of all time...
09-03-2013, 01:12 AM
#39
LOL I almost never read the time stamps, I found this on the new posts shit I was like "what" this idea has been thrown around. I posted this at 4am. lol nuff said
It's cool man. Not even trippin. Do wish you would have gone through with it. Would have been cool.
1996 Infiniti G20
09-03-2013, 02:29 AM
#40
DUDE DID YOU EVEN READ THE THREAD!
