11-01-2012, 08:50 PM
Hid help
I'm About to buy my Hids from ddm tuning. I already have the relay for the 9006 bulb and I was going to get one for the fog light bulb 894 bulb does the relay really help much. Need help
11-01-2012, 09:15 PM
i just bought the hid kit itself, no error eliminator or anything like that, its just plug and play.
ive got the 8000k 35w Slim ballast HID kit from them. had it for about 2 years now with no problems.
Originally Posted by Oldsnut
Originally Posted by tipnitty
11-01-2012, 09:17 PM
I know they last long but should I get a relay for the fog light or not worth it
11-01-2012, 10:03 PM
umm im not sure on the fogs, i never got the hid fogs. someone will pop in and answer the question. but i doubt you need it.
11-01-2012, 10:05 PM
I run with my fog on just has much has my headlights
11-01-2012, 10:27 PM
there is a direct fit bulb number for the hids on here. little bit of searching you should find it. DO NOT run a 55w kit in the fogs, must be 35w. dont bother with them if you have cracked or leaky housing, you will just blow bulb after bulb.
11-01-2012, 10:39 PM
yeah 55w will melt the housing from what ive heard, or the wiring.
11-01-2012, 11:56 PM
Yes, do get the relay harness.
It NEVER hurts to have bigger wire to the lamps than the thin spaghetti stuff GM used factory.
RwP
11-02-2012, 01:31 AM
The relay not a bigger wire it just hook to the batterie for my power right
11-02-2012, 08:26 AM
⌘ Irish Pride
First of all, it's a harness. Not a relay. Second of all, get it. Faster ballast charging, more reliable and less likely to blow a fuse. I have ran with and without harnesses, and I can tell you, it is definitely worth it.
Done lost my mind
11-02-2012, 10:34 AM
The RELAY? No wiring, you're right.
But hanging a relay in air does nothing - you'll need wire to interconnect everything.
So, the HARNESS with the relay - it SHOULD be bought with heavier gauge wire than factory.
THAT is where the advantage comes in.
Besides, you've got a relay in the wiring already ... it's right there in the underhood fuse block! Check your service manual (you DO have one, don't you? If not, GET ONE - Preferably a Helm manual, either new from www.helminc.com or used off eBay - used will claim to be a factory manual, it will be, since Helm did the printing for GM and others.)
RwP
11-02-2012, 10:51 AM
all you need is the kit and harness, plug it in, and go..
11-02-2012, 01:16 PM
I ran the ddm HIDs in my fogs and about half the time, one light wouldn't come on at start up, just had to turn the fogs off then back on and it was ok, but unless you are parked somewhere where you can see your reflection, you didn't know if it was on or off to start with unless you got out and looked.
11-02-2012, 09:36 PM
I'm going to get the relay from ddm tuning with the fogs
My 9006 are going to be 4300k slim
My 894 are going to be 3000k slim
Any idea where to but the Ballast at so they don't get mass up and brake
11-02-2012, 11:17 PM
uhh, i would get 6000k or 8000k those are really best lighting.
the ballasts come with the kit.
11-03-2012, 12:44 AM
Err - no.
They are BLUER, but that's not BETTER.
Actually, the human eye has its best sensitivity in the 4300K to 5000K range.
By the time you get to 8000K, you've gotten about 2/3rds of the rods in your eyes deactivated (no red or green!), so all you're using are the less sensitive BLUE rods.
Better to get into the red/green overlap and use 2/3rds of your eye, instead of only 1/3rd.
I suggest you study up sometimes on human spectral sensitivity.
11-03-2012, 12:45 AM
I'm going for visibly at night. And I know they come with the kit I'm asking we're should I put the ballast under the hood at
11-03-2012, 12:47 AM
I'm getting headlights in 4500k and fogs on 3000k
11-03-2012, 02:30 AM
below/behind headlight.
11-03-2012, 10:16 AM
How you mount the below or behind it
