01-28-2010, 09:06 AM
Loseing coolant
Car is NOT overheating and there is a little bit of coolant just under my overflow bottle. The hoses that go into the bottle are fine. The overflow hose is way under the front of the bottle, but there are small traces of coolant along the inside of the fender all the way back to the suspension hub.
Not an insane amount of smoke/steam comming from the tail pipes. A little bit at stop lights and at idle (my commute is only 8 minutes) but when I'm moving, nothing. Plus it's been cold here. Oil is clean, coolant is clean
Also my heat/defrost is acting weird. Nice and hot with the vent settings after warmed up of course, but put on defrost is gets cold. If I turn the knob to all the way cold, it gets colder. After a few minutes the heat comes up but the windows still fog up..
I just played around with the HVAC vacuum line, I think it was cracked because it snapped off pretty easy in my hand. I streached the rubber hose for now. I'll go to Advanced tomorrow morning and pick up some vacuum hose and fix that. Also. The 90* elbow that goes on the PCV valve, anybody know the part number at which store. Mine is cracked and the one on Advacned's web site is wrong
01-28-2010, 10:31 AM
I had a similar prob in my grand am... after searcing it was a tiny hairline crack on the fenderside of the reservoir. just below the seam.
01-28-2010, 10:48 AM
open your bleeder, i bet there will be air in there, don't ask me now, just open it once it's fully warmed up.. open it and bleed the air, drive 10 miles and bleed again, keep doing this until all air is gone, and i know it won't stop... i'll let you know when you get back to me
01-28-2010, 02:15 PM
I hope not, I just had that bottle replaced.
Nate, my mech thinks there's air in the system too. I'm going to be heading over to him because I have to replace my door hinges. I'll gladly pay somebody to do that. Did it on my Cougar. Once is enough
01-28-2010, 02:21 PM
just bleed it yourself? it's not hard lol
01-28-2010, 02:25 PM
Which bleeder? bottom of raditor?
01-28-2010, 02:38 PM
AleroMoB
NO, i think he means on the heater tube, on the front valve cover.
2001 Oldsmobile Alero 4Dr GL2 w/ 2005 GAGT Motor
CC & PB, Tinted Tails, 3K HIDs (Lows/Fogs), GAGT Mirrors, Flowmaster Exhaust, D/S Rotors, CAI, Rockford Fosgate T400-4 T800-4, 1 15" C3, Rockford F 5.25/R 6x9
01-28-2010, 02:42 PM
bottom of the radiator... after running the car!?! sweet jesus man! do you not want to have a face left!?!
01-28-2010, 02:48 PM
OK Yeah on the bottom of the raditor made no sense
01-28-2010, 02:52 PM
Is this the bleeder screw you are talking about?
And if so, what size screw is it? I'm limited on tools right now
01-28-2010, 04:10 PM
yes. thats it
01-28-2010, 05:57 PM
the top one is an 8mm, undo it maybe four tunrs, and you'll see bubbles, and then coolant
01-28-2010, 08:17 PM
Actually it was a 10mm.
I opened it and saw some air bubbles. I opened it and then started the car and got it up to operating temp.
Seems to have helped a little bit. Let's see what happens next
When I was doing the bleeding I thought I saw some steam from under the TB area. I'll look in the daytime and see if there is a leak there
01-28-2010, 08:43 PM
couldnt have been a 10mm, if you took the entire thing out, to expose a hole, and you were able to run the car without a torrent of water, your pump is seriously bad
01-28-2010, 10:18 PM
Oh, I didn't know it was 2 parts. I opened it up with the 10mm but after you said that, I looked at the pic again and see the second bolt on top
OK I'll try again when I get to work
01-29-2010, 03:51 AM
This seems to be going around. I've been losing coolant lately and my mother's Malibu just developed a huge leak under the TB and dumped all the coolant in a 5 mile ride
01-29-2010, 07:37 AM
ALEROMOD RAPIST
My car's going in today to the mechanic. Been losing coolant very slowly, too, for quite a while now.
01-29-2010, 06:06 PM
ALEROMOD RAPIST
MOTHERF_CKER!!!!!!!
April 2004 my LIMG was replaced under warranty by the dealership. 50,000 miles later I find out from my mechanic that my LIMG went bad again and is at a point where I'm in danger of the coolant mixing with the oil so the car's going to have to sit until at least next Wednesday before they can get to it and my $1200.
Turns out there's 2 different types of gaskets for the LIM - the original one that would go defective 80% of the time and the replacement style which wouldn't. Guess which one the dealership replaced the bad one with?
Called the dealership that I bought the car from (ordered new from the factory and repaired under warranty 2 years later) and explained the situation to see what they could do for me. I normally get extraordinary outstanding customer service from them (they're primarily a Cadillac dealership), but the asshat that answered was a total douche. When I asked him what it would cost for me to have them repair it he said he was too busy to look it up. When I pressed him he said his "boss was calling" him so he had to go. F- them! They just completely lost me as a customer.
But now I have a HUGE repair to undertake (again!), no immediate funds to cover it, and other sudden huge expenses elsewhere also all hitting me at once (emergency vet bills, tv/vcr needing to be replaced, home repairs, etc.). At least I'm actually getting a bonus in March which should help somewhat pull me back out of this hole.
01-29-2010, 06:11 PM
pretty much how my injector problem hit me, yesterday...
at least misery has company, eh mitch?
01-29-2010, 06:21 PM
i gave it all to you, mine is running flawlessley
