04-26-2005, 05:27 PM
#41
Hewy Ryan, the springs are easy enough to install, why not just buy the springs now, tint your windows now, then upgrade the struts when you get more money saved? ( that's what I'm doing, the spring install is easier than you would think, trust me )
05-14-2005, 11:30 AM
#42
even if you want to spend the few hours doing the springs again.....you have to get a $65+ alignment everytime you redo the suspension, do the springs/struts at the same time
2001 Alero GLS - Sold!
05-16-2005, 02:05 PM
#43
ok so...what gives u the most drop? sprint or ST?
05-16-2005, 06:24 PM
#44
same company different names if im not mistaken. sprint and spring tech are made by the same people and will give you the same outcome... i think.
05-17-2005, 02:10 AM
#45
Yep.
<span style=\'font-size:8pt;line-height:100%\'>Every now and then when your life gets complicated and the weasels start closing in, the only real cure is to load up on heinous chemicals and then drive like a bastard from Hollywood to Las Vegas. Just roll the roof back and screw it on, grease the face with white tanning butter and move out with the music at top volume, and at least a pint of ether.
-From the book Fear and Loathing in Las Vegas by Hunter S. Thompson </span>
05-17-2005, 05:19 PM
#46
I want these, but i have 20's on my alero.
will it still work?????
05-17-2005, 11:46 PM
#47
nope
05-22-2005, 10:59 PM
#48
you just need to do some work to tuck the 20's under there-someone on cardomain w/an alero did it and said he had to do some work to fit them under there
05-29-2005, 05:07 PM
#49
20's will work, all you need is a lower profile tire and its no difference
the problem is that most 20's are 20x8.5, which wont work. you need 20x7, maybe 7.5. do a search, some people have 20's and are lowered
20's on a alero is pretty gay
05-29-2005, 05:46 PM
#50
hmm....20's and lowered? ouch...
05-30-2005, 10:23 AM
#51
so ud perfer 20's and not lowered? Ew
05-30-2005, 06:34 PM
#52
Hehe, true!
05-31-2005, 08:04 PM
#53
I'm sure it has already been said but where is the best place to get cheap springs.
DO WORK
06-12-2005, 01:00 PM
#54
i got my mrom suspensionmax.com
06-14-2005, 12:25 AM
#55
Received mine from sus.max for $150 shipped in 6 bus. days-everything was in good order.
07-06-2005, 10:49 PM
#56
Am i just retarted or something, because i cant seem to even pull these springs up on suspensionmax.com, i go to online cat. and then is says select make, so i select oldsmobile and then it says no parts found for this vehicle, is that what everyone else got??? LEt me know cause i am feeling really stupid right now
07-07-2005, 07:29 AM
#57
Right Here
The ones you need are towards the bottom, just look @ the years listed on the left. *note* The advertised 1.50 inch drop is under-rated, you'll see more than that.
07-08-2005, 03:37 PM
#59
get them fromebay...it will be a few bucks cheaper....
09-27-2005, 02:59 PM
#60
hey guys, i've been thinkin abt gettin these for a while... any of u guys use them in the winter?
