11-29-2007, 01:22 AM
#21
It was a buried 55 gallon drum that was sticking out of the ground, hit it and went vertical and sled almost crashed on me. It would have been merciful at the time, when I landed it was not good, thought I broke my back.
Back on topic.
11-29-2007, 11:32 AM
#22
Back on topic.
That's not the snowmobile's fault though... but I understand not wanting to try it again. If you buy a set of these. You must do a review on them. I'm interested in them, but don't want to shell out the $150 for them if they are not going to make any difference.
04-29-2008, 11:04 PM
#23
5 months old but has anyone tried these yet? i'm still curious as to if they're worth the money or not
03-26-2011, 10:46 PM
#24
pacho they came out with a new line they are ididiums and lowers the price 12.99 i bought them i will be installing wensday and posting results!!! i wasnt going to buy them but a few sceptics out there posed their dyno results before and after and i think the smallest gain was 5hp so ill post as soon as i get them in. you gotta disconnect battery and run it for a full tank aprently so we will see
03-26-2011, 11:46 PM
#25
iron... check the dates....
03-27-2011, 02:42 AM
#26
Why does it matter? I would like to see what people have to say about them..... since nobody posted a review.
03-27-2011, 07:50 AM
#27
Why? That doesn't make any sense at all? We're been over this 1000x on the site. New "fantastic" spark plugs don't do anything but produce spark and can't do anything more than the old coppers did 20yrs ago. They can't increase your HP unless your car is seriously modded and sorely lacking in spark.
03-27-2011, 10:21 AM
#28
And that brings up the question: what makes a car lagging in spark?
I thought there was a thread devoted to this as well and the conclusion was that the generic stocks will do what any other gimmicked product will do. I am always interested to see what is new and exciting out there though. When I get my tune, I will be asking the same questions to see what little bit helps. A little bit here and there does add up.
03-27-2011, 11:22 AM
#29
cher i know im not expecting anything alls i know is ive read hundreds of posts literally on the web and seen people personally take the time to dyno their cars to do before and after and seen results. and as far as the battery thing i dont know the technicality behind it has something to do with the compter the manufacturer claims. i pay 12.99 for the plugs i use anyway so i dont have a problem trying these out.
and i say yes we have been over spark plugs probably letirally as many time as u said but i think its fair to say this is a little different and its worth a shot as is any new product. theres alot of buzzz lots of questions im sick of wondering so lets see what happens no harm done its not alot of money.
03-27-2011, 11:32 AM
#30
As an Electrical Engineer I'm curious to know how they pull off this 'magic'. The same amount of energy is going into any given spark plug so how can 'more' be coming out of the tip? I upgraded to MSD components, this I understand...
03-30-2011, 11:16 AM
#31
haha almost 3 yrs since that post..still want to see results so post up today iron after install
04-12-2011, 12:24 AM
#32
there is no question increased gas milage tested it 3 times. i gained 4mpg to me thats awesome. as far as more power i dont see or feel it at all so deff more for the mileage improvement
04-13-2011, 12:05 PM
#33
very cool. Did you keep all your driving the same as you did before?
04-15-2011, 11:51 AM
#34
no its the same routine i was kinda surprised i thought the effect of these would be opposite. id say yes 12.99 is alot for a plug but with such a improvement its worth it and the plugs i took out were delcos and a year old
04-15-2011, 12:34 PM
#35
the logic doesn't make sense as to why your mpg would change. Its not like your car is magically more aerodynamic, has more air coming into it, getting better traction, using less gas....etc
OR.. your mpg could have changed because we just went from ball shrinkingly cold air to slightly warmer spring air, and the plugs barely did anything different from the last ones.
My mpg went from 22-24 highway to 25-27 by changing my tires. Coincidentally, it was also done on the same weekend I changed from my winter tires. Do tires make THAT much of a difference? No. Air temp does!
04-15-2011, 01:17 PM
#36
cher u have never been wrong with advice for me but im sorry this time you are go buy them try them and if they dont increase your mpg return them. trust me you wont after you see.
04-15-2011, 01:45 PM
#37
If someone could give me a good sound reason as to why this could be possible, other than "my MPG went up because they are so awesome it had to" then I would go buy a set and have them in my car tomorrow. MPG is a HUGE deal to me. But I'm not going to buy snake oil without concrete proof that it works.
And simply put, there are too many confounding variables in your testimony to make me believe its possible.
04-15-2011, 02:06 PM
#38
ok ill pay for half just to prove my point
04-16-2011, 12:40 AM
#39
Hmm...just playing devil's advocate but if the plugs spark more efficiently and in a more timely manner, doesn't that equate to a more efficient running engine creating less waste (or gas usage otherwise)?
Also, switching tires I would be more interested to see the difference in the tire pressure of each. My car gets better MPG in milder climates because i am not running it extra or warm it up, or running the AC to keep it cool. Less peripherals, less power draw, more efficiency. However, you can gain a couple mpg just by ensuring your tires are properly inflated.
Does that mean these plugs are the tits? Who knows...you may have just needed a newer fresh set of plugs in case one of the million things happened to the other set. In any case, I will bite and give it a shot next go around just for the fun of it.
04-16-2011, 02:06 AM
#40
when you do record the mpg like i did to silence the skeptics please
