05-25-2014, 02:21 PM
#181
05-25-2014, 02:56 PM
#182
Sounds really good, Chris.
Nice work.
05-25-2014, 05:05 PM
#183
Nice work.
X2 sounds awesome.
05-26-2014, 04:29 PM
#184
Originally Posted by Papa Rad17
X2 sounds awesome.
X3.
05-26-2014, 04:45 PM
#185
Truck Ya !!!!!
Bessie Braddock: “Sir, you are drunk.”
Churchill: “Madam, you are ugly. In the morning, I shall be sober.”
05-26-2014, 07:35 PM
#186
Looking clean man!
Her name's Ally. She may be plain, but she's not the same.
05-26-2014, 07:47 PM
#187
That was some short lived fun.
Broke the turbo.
Need a new one ASAP. The TiAL housing, even using high strength M6 bolts, Nord-Lock washers, and Rocksett enginering adhesive, allowed movement of the CHRA/compressor side of the turbo independent of the turbine housing. Basically, you could wobble the compressor/CHRA side. Apparently it has wobbled enough to cause the turbine fins to collide with the turbine housing's interior, and destroy the fins and also overheat the bearing assembly (maybe) because it sounds bad. But it still spins a long time when the car is off, but you can see the side to side play now.
I didn't expect this turbo to last as long as it did. I bought it used and abused for half price. I used and abused it.
Edit: Ordered a new one.
Countermeasure for failure:
The CHRA will be tack welded to the TiAL v-band turbine housing. This will prevent the CHRA from moving and allowing for friction and wear of the turbine wheel.
I realize this is unconventional, but I do not need to ever take it apart nor do I need to clock it any other way than the way it's installed.
05-27-2014, 08:37 AM
#188
I Have ONE NUT
That sucks Chris, but at least you have another on the way.
05-27-2014, 08:48 AM
#189
Indeed. I also e-mailed TiAl for recommendations:
Originally Posted by Chris --> TiAL
Hello,
I have a GT30R SS 0.63 turbine housing that I’ve used on my Garrett GT3076R turbocharger for a few years now.
I have had to remove and reinstall the turbo many times over the years due to loosening of the CHRA/compressor side relative to the turbine housing. No matter what I do, how meticulously the turbo is installed, the CHRA becomes able to “wobble” and clock slightly back and forth after the first few drives. This has led to damage to the turbine fins as well as exhaust leaks at the CHRA-turbine seal. The turbocharger recently failed at the turbine wheel and bearings last night after a good amount of high RPM/throttle fun this weekend.
My question is: Do you have any recommendations to increase the clamping force of the CHRA to the turbine housing and prevent any future wobble/clocking after heat cycles?
Over the years, I have used:
1. TiAL Inconel bolts only
2. TiAL Inconel bolts and Nord-Lock washers
3. New TiAL Inconel bolts, new TiAL clamp plates, Nord-Lock washers, Rocksett engineering adhesive
4. High strength bolts, Nord-Lock washers, Rocksett engineering adhesive with everything assembled to extreme detail
The CHRA has wobbled and contributed to failure in all of these cases. For the most part, the bolts have not actually become that loose, they feel tight. It’s just that the provided clamp plates seem to not provide enough clamping force for the CHRA pressing into the turbine housing. Until all 6 bolts are removed and re-tightened fully, the CHRA can clock and wobble. Only at that very last miniscule amount of bolt torqueing does the CHRA become firm. But after a few heat cycles it relaxes and wobbles.
Basically I’m wondering if you have any advice to prevent this from happening on the new GT3076R that I ordered. Do you, can you produce turbine/CHRA clamp plates that are thinner in the flat section to maximize the clamping squeeze in the raised ridge that presses the CHRA into the turbine housing when the bolts are tightened?
My only idea and option I can see is to tack weld the CHRA to the turbine, which I realize is quite unconventional, but my turbo is never apart and never needs re-clocking from the original installation position. Please let me know if you have a better solution available.
Thank you,
Edit: What a surprise, they redesigned the clamps in Dec 2013. Too bad no one has any in stock.
http://www.verociousmotorsports.com/...-Housings.html
Wonder if TiAL would ship me some direct. I'm sure the new design would help if not solve the issue without welding.
05-27-2014, 05:51 PM
#190
Hooray, a set of free improved lock plates from TiAL after my concerns were expressed to them. New turbo comes in Friday, should be up and running on Friday.
05-27-2014, 09:59 PM
#191
keep up the good work man !!!! this car is just amazing... lots of trial and errors but the important thing is to learn from our mistakes and badluck... and I know what I'm talking about.... the feeling you must have when driving it... some people can't understand the importance of building their own car...
05-28-2014, 10:10 AM
#192
Thanks, it is fun.
I thanked TiAL for their support and said I'd continue to recommend their products.
Originally Posted by TiAL
We are happy to hear that. I went back in the shop this morning and got your package around. It should be shipping out today, arrival should be by Friday. Ill try to get some tracking information from the shipping dept. for you.
Again, we appreciate your business, and happy motoring.
05-29-2014, 06:54 PM
#193
05-29-2014, 07:55 PM
#194
Scared to get yout hands dirty?
Originally Posted by Oldsnut
Originally Posted by tipnitty
05-29-2014, 09:09 PM
#195
when you work on your cars enough you'll realize it's a hell of a lot easier to do things with nitrile gloves
- no transfer of grime between parts if you don't want to
- i can take calls quickly without dirtying my phone
- my hands stay clean so i don't have to spend 30 minutes trying to get grease/oil whatever fluids/dirt that are extremely difficult to scrub out
my hands and arms and entire body has been dirty enough over the years working on vehicles. i'm a bit smarter now when it comes to processes.
05-29-2014, 09:42 PM
#196
Im just yankin your chain haha. I dont mind getting dirty. Gives character
05-29-2014, 10:10 PM
#197
^this
05-30-2014, 05:39 PM
#198
New turbo came in... clamp plates from TiAL still in transit.. wtf.
They shipped from a place literally one hour away on Wednesday. It's Friday and USPS still has not delivered it. Hopefully they come in Monday and I can get this thing back running. Pissed.
05-31-2014, 01:40 PM
#199
Can't wait to see her at the 14' homecoming meet!
06-01-2014, 02:44 AM
#200
Try messing around with urethane, then tell me how you feel.
BTW urethane is a stronger RTV gasket maker. it's meant for windshields but can be used to seal up anywhere where you don't want water coming in.
1994 Olds Cutlass Supreme
1996 Infiniti G20
1993 Chevrolet Lumina Z34
1989 Buick Regal Limited
