Old 01-07-2004, 02:57 PM   #1
leroBob
leroBob is an unknown quantity at this point
Just curious who here has replased their stock wxhaust wheter Borla or SLp them selves. if so how easy can't imagine doing this with out a hoyst, and how they if they did go about making the bumper have two exhaust ports. :unsure:
leroBob is offline   Reply With Quote
Old 01-07-2004, 05:09 PM   #2
r53silver91s
r53silver91s is an unknown quantity at this point
Installing the Borla was eazy, its a direct bolt on so all you gotta do is take the old one off, you'll have to cut it though to get it off (well at least I did), and then put on the new one.
Well now that I'm thinking about it we had to use a blow torch on the bolts that connect to the cat cause they were all rusted out and wouldn't budge.
And I have the borla for a grand am so we had to cut out some of my bumper cover only because I got hit on the rear pass. side and my reinforcement bar was crushed so it caused the exhaust on that side to sit higher and back a little farther than normal. I don't know if everyone has to cut theirs or not.
Install should be the same with the SLP, but somebody with that exhaust will help you out.
And I really can't make out that last question there, maybe reword it somehow.
<a href=\'http://members.cardomain.com/r53silver91s2\' target=\'_blank\'>http://members.cardomain.com/r53silver91s2</a>
<img src=\'http://invision.aleromod.com/uploads/post-24-1088131656.gif\' border=\'0\' alt=\'user posted image\' />
r53silver91s is offline   Reply With Quote
Old 01-07-2004, 06:01 PM   #3
I had my exhaust done at an exhaust shop. It's all custom work. I also had the second cut-out done at a body shop.
Check out my web page to see the cut-out. The body shop did a really good job, It looks stock
Old 01-08-2004, 11:41 AM   #4
leroBob
reddog what did all that run u $$$$?
Old 01-08-2004, 05:58 PM   #5
ImSoBored
ImSoBored is an unknown quantity at this point
Send a message via AIM to ImSoBored
I had the shop put my SLP on
SLP
I personally wouldnt recommend doing this yourself, unless you have access to the required tools
I also had mine welded on(which I cant do)
My bolts to the cat were also rusted, so they just cut the connector off of the SLP and welded it straight to the old connector
ImSoBored is offline   Reply With Quote
Old 01-09-2004, 12:11 AM   #6
Fast Eddie
I installed my borla (for an alero) in my driveway. be forewarned though you have to get the ass end WAAAY up in the air. I think I measured the rear cross member at 26" off the ground on two 2X4s and two 4X4s on top of the jack.
I'm on a boat.....
