02-27-2007, 08:22 PM
#21
02-27-2007, 09:07 PM
#22
funny thing is.. i even commented on that thread.
i thought for sure you didn't do a keyless system, but apparently i just can't read....
relays, wiring and connectors.. hmm... just need a good site for a big variety of switches... or a place to put switches that are easy to reach, but arent obvious...
02-27-2007, 09:13 PM
#23
V.I.P. Punching Bag
ya i would kill to know how this is done, if we had a damn good how-to and i have lots of time on my hands and is fairly inexpensive, i would soo do it!!
10-30-2008, 11:45 PM
#24
sorry for a old thread revival but I'm new around here just got a 2001 5spd alero and I'm looking into a push button start to take place of the hazard button. Does the 2001 have the passlock or whatever it is that will give me a pain in the ass time trying to wire up the push button? If so..f that.
10-31-2008, 02:29 AM
#25
Yep, it does have passlock. It can be disabled however.
10-31-2008, 07:41 AM
#26
Originally Posted by AftermathAlero
Post a how to....no one wants to figure it out...LOL
10-31-2008, 07:52 AM
#27
i posted a similar thread when i was new, no one answered me...
10-31-2008, 08:10 AM
#28
how do you disable the passlock... mine is getting pretty bad and i don't want to buy a new ignition cylinder
10-31-2008, 08:51 AM
#29
it requires 2 relays, 2 switches and 1 push button theres a hint for you
10-31-2008, 09:19 AM
#30
I believe you can disable this with a tuner as this was something that was done when my car got tuned.
10-31-2008, 10:00 AM
#31
I can't imagine why anyone would want one of these.
10-31-2008, 12:17 PM
#32
its extra work but eh...just gives me a "flashy" mod to do in my spare time if im bored....makes all the ladies go omg thats so cool..haha
10-31-2008, 02:11 PM
#33
No one answered you because no one else but aftermath has done this mod I think, and he would be the only one I would take a how to from, but I understand that its a bitch to put one together so I was just throwing it out there since he mentioned that he has done this mod....Most of us I'll say knew he did this mod.
10-31-2008, 05:29 PM
#34
Grim has done this mod also
11-01-2008, 01:12 AM
#35
We did it on a buddy's focus. Just wired an button into the start wire coming from the cylinder.
11-01-2008, 03:59 AM
#36
As posted by aftermath.. to bypass passlock:
Its simple, Without cutting the wires yet, check the resistance in the yellow passlock wire and the black ground of passlock. Then goto radioshack or electronic store and get the same resistance resistor and solder in. (only cost a couple of cents). Then its permently bypassed. Same thing using the DEI 555L module, but don't cost anything. hehehe Most alarm shops will sell you that module to make money off of you when doing the remote start. If your lucky to find a shop that don't have the make money the easy quick way, they won't sell you the module and they'll solder in a resistor instead. Depends on who you go to for installment.
After you do that it's just a matter of doing the wiring for the wires from your ignition cyl, put them all on switches (one for on/acc, one for run.. I'm sure there's more), and put a pushbutton on the crank wire.
Obviously it's a little more complex, but as long as you know basic car wiring/ how to wire up relays you'll be fine.
11-01-2008, 03:19 PM
#37
You got beat by an Alero!
hmmmmm interesting
11-22-2011, 02:36 PM
#38
⌘ Irish Pride
Thread revive!! So I'm just trying to put in a push button in addition to the keyed ignition. My thinking is, if I have the keyed ignition in the RUN position, and have a button spliced into the START wire, will that start it up?
Also, I think the wire needed is yellow and runs to the IGN-SW BATT1 fuse thats under the hood.
Any input??? I don't want to try this and destroy it all because of one dumb mistake.
Done lost my mind
01-08-2012, 03:10 PM
#39
⌘ Irish Pride
Ok, so a couple months later and I've figured it out. Will post up pics later. Very pleased
Done lost my mind
01-08-2012, 03:21 PM
#40
AHHHHH IVE WANTED TO DO THIS FOR SOOOO LONG!!!!!!!
is it possible to post a vid
just call me "Doc"
Check out my alero!
Aleromod Showcase Video
