Old 01-25-2006, 09:37 AM   #21
brsexton
Brakes
Bearings
Brakes
and more brakes
You would think GM would have gotten some of these common issus worked out by the 03's and 04's came out, but NOPE. They still have the same damn brake and bearing issues.
2005 Honda CR-V AWD
Old 01-25-2006, 10:26 AM   #22
Nik1128
The window tracks are too wide allowing dirt/sand/gravel to fall in there and get trapped.
My suggestion, just take apart your door panel and try and clean out the tracks.
My problems...
Window scratching.
Overhead carpet pealing.
Window gets stuck and wont roll down.
Right rear door leaks air.
Right now the engine is missing slightly, but I beleive new spark plugs/wires will fix that.
The light fixtures in the rearview are loose causing the lights to sometimes not illuminate.
300 miles to a tank of gas in the winter vs. 400+ in the summer.
Those are the only things I can think of w/a '99 and almost 40k on it.
Old 01-25-2006, 09:47 PM   #23
slver5speed
humm lets see first was the shifter wouldn't go into reverse 2 times I fixed that problem the 2nd time myself. Then the wheel bearing both of them. Next was the brakes which are going bad agian. put a groove in the rotor first day I had them. then the window track and windows comming of track and getting the sandish groove. Then to top it off the master clutch which went out and also broke the clutch pedal in half very poopty desing. then to top off my cake when the master clutch went out they towed it and, put the hook on the trailing arms guess what that did bent it and now my rear end is f***ed all up squeaky bouncing spinning wobbling pos! not only did they bend it but shifted the whole rear end still waiting on the battle over that one
Old 01-27-2006, 12:23 AM   #24
slowandlow
slowandlow's Avatar
the scratching is cauesd by a two narrow window gap they can widen it had it done and if i ever get a door replaced i have it done too.
Old 02-22-2006, 12:04 PM   #25
battistoni21
battistoni21 is an unknown quantity at this point
Send a message via AIM to battistoni21
I've had my alero for almost 10000 miles now..(bought when it had 75000) The only thing that I had to replace was the fuel pressure regulator. I'm still getting horrible gas but I bet its just from my WAI. My windows just started to scratch about 2000 miles ago
battistoni21 is offline   Reply With Quote
Old 02-22-2006, 12:05 PM   #26
battistoni21
Wow 400 miles on a full tank of gas? Was that all highway?
Old 02-22-2006, 12:10 PM   #27
i haven't had any problems yet.. but i only have 38K on my '03.
and i have the v6 (no engine mods) i get about 30mpg, highway.
Old 02-22-2006, 12:17 PM   #28
battistoni21
Yeah, thats one thing i forgot to leave out, I heard from one of my co-workers, and from my dad, who works for the federal mine inspection agency. .... he said that the government cars(only the aleros) have front brake problems. He said that for every 2 out of 3 aleros, 2 of them have that problem. I also had/still have problems with my front left HUB assembly. I havent gotten that fixed yet though.
Old 02-22-2006, 04:28 PM   #29
hpt_playboi_03
hpt_playboi_03's Avatar
hpt_playboi_03 is an unknown quantity at this point
Send a message via Yahoo to hpt_playboi_03
here is my list of stupid problems:
-brakes. and right after i got those fixed, my freaking calipers froze up.
-window scratches up my tint, and i had a lil plastic peace on my driver side window that broke up, and my window would just drop down instead of roll down.
-my headlights and guages wouldn't go off at one point and no one could figure out what that was.
-had to get a regulator for my back driver side window.
-my cd player could say calibrate and no one could figure out what that problem was.
and that's all.
hpt_playboi_03 is offline   Reply With Quote
Old 02-23-2006, 08:32 PM   #30
Alero2k4
Alero2k4's Avatar
Alero2k4 is an unknown quantity at this point
I really want to find out what that problem is...it did it again yesterday.
1.3l Renesis Rotary
Alero2k4 is offline   Reply With Quote
Old 02-23-2006, 09:04 PM   #31
hpt_playboi_03
When i took mine to the GM dealership, they couldn't figure it out. when they hooked the car up to the diagnostic machine, it didn't say nothing. i just gave up on it.
Old 02-26-2006, 01:08 PM   #32
Eh_nigma
the "Why Not?" Guy
Eh_nigma's Avatar
Eh_nigma is an unknown quantity at this point
Send a message via MSN to Eh_nigma
All I can think of is this:
1.Pass. Window coming off it's tracks (4th time two weeks ago)
2. Fuel Guage sticking (acting funny)
3. CD player will not eject CD fully
-Everything
"Why an Alero?"
-Why the hell not?
Eh_nigma is offline   Reply With Quote
Old 03-05-2006, 10:59 PM   #33
The only problems I've had with my Alero sinse I bought it was the Rear Defrost not working... something about a little plastic piece that melted... it would cost me about $300 to fix... at least that's what the dealership said... bunch of crap if you ask me.. umm.... when my car runs, sometimes it's below 1000 rpm, and sometimes it will be right on 1000 rpm.... when it's below, it feels like the motor shakes a little.... Other than that, everything runs great! I've had no problems with the windows though.... my windsheild is a little chipped... and my cd player is really picky. and that's all... It's pretty clean...
Old 03-06-2006, 01:25 AM   #34
1WhiteOSV
Brake Rotors(all Alero's)
Lower Intake Manifold Gasket (3400 V6)
Window Regulators (all Alero's...mostly 2 doors since the door is heavier..it slams harder causing them to break)
Wheel Bearings (all Alero's)
Foglights cracking/leaking (all Alero's w/ foglights..duh)
These are some of the most common problems w/ Alero's and Grand AM's
Old 03-06-2006, 06:32 PM   #35
jeremythebear
jeremythebear is an unknown quantity at this point
2 steering racks, 1 under warranty
2 transmissions, 1 under warranty
1 window regulator
1 battery
1 fuel pump
numerous little odds and sods
222,000 km on her (2002)
138,750 miles for our metrically challenged neighbours
jeremythebear is offline   Reply With Quote
Old 03-06-2006, 09:52 PM   #36
scsralero
scsralero is an unknown quantity at this point
over 117000 miles and im on my third drivers window track and thats starting to go out
bumper warping and cracked fog light, and blower motor resitor but im fixing that tommorrow(again) , but i have figured out what the starting problem is and maybe a way to fix it cheap! the problem is the security system(passlock 2 ignition) but as soon as i test out my theory i will tell you guys how to fix it and its only going to cost around 20$ so when i try it i will post under the how to forum.
scsralero is offline   Reply With Quote
Old 03-08-2006, 08:28 AM   #37
Menace
@Kutztown University PA
Menace's Avatar
Menace is an unknown quantity at this point
Send a message via AIM to Menace
Ive gone through 2 window regulators and tracks
New Power steering pump
New Water Pump
New battery
those are thinks ive had to change
if your cd is getting stuck when comming out of an aftermarket headunit then take out the cd player and unbolt it from the case then move it all the way to the end so its snug and rebolt it on, most also have clips so you unclip move it forward reclip.
Alero is sold!
2007 Scion tC in driveway!!
Stuff for sale
http://www.aleromod.com/forums/showthread.php?t=13919
Menace is offline   Reply With Quote
Old 03-08-2006, 08:19 PM   #38
pimpnalero99
I've had the starting issue, gas gauge goes crazy after it drops around 1/4 of a tank, cruise control went out, and glass scratching.
Old 03-12-2006, 09:23 AM   #39
robz02alero
robz02alero's Avatar
robz02alero is an unknown quantity at this point
Send a message via Yahoo to robz02alero
78,000 miles and a scratch on the glass
owner/operator of : The Pinnacle of Clean Auto Detailing Service www.pinnacleofclean.blogspot.com
Supporter of Aleromod.com
OIF VETERAN X3
COMING HOME SOON
robz02alero is offline   Reply With Quote
Old 03-18-2006, 08:18 PM   #40
Wildman
Wildman's Avatar
Wildman is an unknown quantity at this point
Let's see....
2x Drivers side window regulator
2x Blower Motor Resistor
1x Rack and Pinion
1x Front Wheel Hub Assembly
1x Belt Tensioner (literally fell apart)
1x Power Steering Pump
1x Water Pump
1x Alternator
1x Cruise Control keypad (right hand side)
1x Lower Intake Manifold Gasket
1x Replacing 6 Fuel Injectors (to solve the stalling on warm start issue)
1x Rust Creeping up the Dog leg (Both Sides of the car [not fixed yet] )
Mild Window Scratching on all windows
----Some insidental things are.....
Brakes / Rotors every 6 months
Battery
Belt
3 foglight assemblies (and need another one again now if not both)
1x Right Front Tie Rod End
1x Lower Control Arm Bushing
New front coil springs (after one of the original ones literally broke)
New front Struts
----Things I need that I have not gotten around to fixing----
Needs another Right Front Tie Rod End (Loose - Noticed this today when changing my brakes)
Needs another Wheel Hub Assembly (constantly throwing ABS / Trac off lights)
Needs a new button on the seatbelt that keeps the buckel from sliding all the way down to the floor when it's not in use.
Need 4 new tires for spring/summer (comming up)
Oh yeah, and she needs washed and cleaned Inside and Out really bad
About all I can think of for right now.....
CAI - Borla Cat-back - S&S Headers - DHP - AFPR
Wildman is offline   Reply With Quote
