07-02-2008, 10:25 AM
#41
great quality GM parts, i have a 2 door Alero with 80,000 km i bought the car and driver window had the broken white clip, i needed the part right away because it was middle of winter and my window wouldnt go up, no one in my area supplied it a 5$ part turned out to be 130$ i had to buy a damn window cause it comes with the stupid white clips on it. oh yea and 2 months later the passengerside clips broke.
09-07-2008, 09:39 PM
#42
Junk
My window regulator crapped on me yesterday. I heard a loud SNAP while putting my window up after leaving the drive through at McDonalds. Then my windows just fell down into the door and I heard all sort of parts falling and rattling around inside the door. I took the door apart today, and this is what I found... I'm guessing I can just go to the parts center at my GM dealer and get the white plastic clips. Is that all I need?
09-07-2008, 09:46 PM
#43
i havent had any problems with the regulators but i had to replace all four actuators.
09-07-2008, 11:19 PM
#44
Its Beer Thirty
You will need the white clips and the adhesive that holds the sash to the window.
09-11-2008, 09:27 PM
#45
Done
So I went and got a new window regulator today. $100 brand new from Milich's junk yard. A new motor came with it, I was a little surprised. The new motor is almost half the size of the old one, but seems more powerful and a little bit faster than the old one. The install went rather well, didn't break anything, and everything was an exact fit. If anyone wants any tips, just ask.
02-09-2009, 08:53 AM
#46
About 6 months later the cheap E Bay window regulator took a crap... This morning... In the cold...
04-11-2009, 09:06 AM
#47
hey, sorry to revive this, but my question is this,
my passenger side window works well, but it seems to squeak REALLY loudly,
now my drivers side,
this window is obscene, it goes down, but with a lot of popping and stalling and really bad noises, and it will not go up without my hand for help.. i took the door apart, and i found everything to be pretty normal, everything looks normal...
what is wrong with my window?? i want it fixed naow...
04-11-2009, 09:29 AM
#48
I would grease the regulator track. Thats the metal part.
Then I would readjust the rubber track/window guides.
04-11-2009, 09:36 AM
#49
umm, more in depth explanation?
04-16-2009, 05:59 PM
#50
The Drunk
My drivers side is like that. I broke a window clip. That caused the window to rip the rubber track and it gets caught evertime I roll it up so I have to go down and up or pull it up myself. You said you already gave it a once over but might double check those white plastic clips and the rubber for rips. (Swung by the stealership and ordered some clips $13 each but they'll be in tomarrow morning I don't want to wait for ebay shipping). It really helps to roll down the window half way.
`03 Alero GL 2.2L Ecotec
05-24-2009, 08:25 AM
#51
reviving this again, i went over a bump last night, and the passenger side window fell in, no apparent reason, go over another bump, and the driver's side fell in.... i need four clips and a regulator,
where to get the clips the cheapest, and the reg. i got was 50$ so im set on that
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting, thats the reg, does it have the clips on it? i dont know what they look like... if it does im just going to replace both my
EDIT, haha! there are eight with this set,
http://cgi.ebay.com/ebaymotors/99-00-01-02-03-04-Oldsmobile-Alero-Window-Sash-Clips_W0QQitemZ250427142904QQcmdZViewItemQQptZMoto rs_Car_Truck_Parts_Accessories?hash=item3a4e9ef2f8 &_trksid=p4506.c0.m245&_trkparms=72:1205|65:12|39: 1|240:1318#ht_7582wt_1191
05-24-2009, 10:04 AM
#52
The window rides in a track.
Your 2nd auction shows the sash clips that Epoxy onto the window. Unless yours are broken you DONT need them. Broken ones are detached from window, so like you roll the window down and it "hops" on its way down or stays frozen to the window frame...
Get your window Regulator from ebay seller Auto & Art. They are cheaper and warranty what they sell. Plus its IN STOCK. They dont have to wait for the distributor.
05-24-2009, 10:21 AM
#53
how much was the auto and art one
cant find that seller, link me please
06-03-2009, 08:00 AM
#54
got two new reglators from local junkyard, new 50$, with motor,
nice and smooth, never broke a clip either!
BTW! they sell the clips at pepboys for 15$ for four!
06-03-2009, 10:22 AM
#55
ok..so i readin all this and tryin to understand. both the clips that ride up an down on the wires broke on my driverside window. when i talked to the dealership here. the clips are $75 a piece. so would it just be cheaper and better to just buy a regulator? i lookin for the route to use less money.
http://www.cardomain.com/ride/3318093
06-03-2009, 10:48 AM
#56
it was just the clips...... ill make a how to or walk you through it, what do you have, coupe or sedan
06-03-2009, 11:33 AM
#57
sedan
06-03-2009, 11:42 AM
#58
sedan
haha, strange, the sedan's window system seems so much better built, anywho, the clips replacement procedure is the same, is the window held up by tape or is it holding itself up?
06-03-2009, 12:32 PM
#59
did have tape holding it up. but summer was close..an weather was decent here i dropped it
11-02-2009, 03:23 PM
#60
The driver's side rear on mine has developed an annoying tendency to fall down slowly, as you drive. It never gets very far before I notice it (few inches usually) and I can pull it back up, or push it farther down, with my hands. It will go down but not back up using the switch. I wouldn't care if it would just stay closed, but since it falls of its own volition, I'm afraid I'll forget to "secure" it one day before it rains. Is this a broken clip, or something else going on?
Driver's side front did the abrupt falling inside door, had that fixed by a glass shop for something like $200. Hoping to not spend $$$ this time!
